Pacesetter Ypipe fitment problem
Old May 30, 2008 | 09:44 PM
Jazsun's Avatar
I have pacesetter longtubes installed and all was good, now I have installed the ypipe (w/ the assistance of a hack saw) and the problem seems to be that the bracket w/ the slots for the two nuts which used to hold the old exhaust and is also used to hold the pacesetter y on the passengers side does not come close to lining up. There is about a 2 inch difference in length, It's almost as if the ypipe needs to come toward the front of the car another two inches but it is not possible since the tubes are as far up on the headers as possible. I bought the ypipe off the for sales section ,is there a difference between the 96-97 and 93-95 ypipes or manual vs. a4?
Old May 30, 2008 | 09:50 PM
camarozz95's Avatar
Mine is the same way doesn't line up thought I read on here somewhere you have to have a new hanger welded in, but I never did never had any kind of problem so you should be fine.
Old May 30, 2008 | 09:54 PM
Jazsun's Avatar
I'm interested in knowing which cars it does lineup.... weird... I was thinking about taking some wire and using that to attach it to the original brace.
Old May 30, 2008 | 09:56 PM
camarozz95's Avatar
I was under the impression it doesn't line up on any year.
Old May 30, 2008 | 10:07 PM
Pyrodawg's Avatar
it lined up fine on my 93.. but i bought mine used so maybe it was previously modified?
Old May 31, 2008 | 07:07 AM
2000GTP's Avatar
My dad fabbed up a bracket and welded it to the pipe for me. Otherwise, as you noticed, it doesn't even come close.
Old May 31, 2008 | 07:52 PM
Sinister95Z's Avatar
When I had a y-pipe, the bracket did not line up for me either. If you insist on using it, then you are going to have and custom make a way for it to work. I think most people just leave it be and let the rest of the exhaust hangers do the work.
HarleyZ28
Oct 5, 2015 06:23 AM
drptop70ss
May 4, 2015 08:22 PM
WildRidez
Mar 27, 2015 08:22 AM
Jazsun
Dec 29, 2014 12:14 PM
