Pacesetter LTs
Old Feb 6, 2007 | 08:36 AM
  #31
SpeedDemon02SS's Avatar
i not too concerned about rusting...i dont drive the car in the rain.
Old Feb 6, 2007 | 12:09 PM
  #32
2000GTP's Avatar
Neither do I, I don't drive in the rain or snow and my car sees very limited driving time each year.
Old Feb 6, 2007 | 12:51 PM
  #33
hmm...point taken. thanks. i still am going to go with the pacesetters, and if i see a consideral amount of rusting, ill upgrade later.
Old Feb 6, 2007 | 12:59 PM
  #34
JoeliusZ28's Avatar
ive had mine on since april, no sign of rust or anything like that.
Old Feb 6, 2007 | 01:16 PM
  #35
2000GTP's Avatar
As I previously mentioned, its kind of a hit or miss thing. Some people have had their coated Pacesetters for years and they show no signs of rust or corrosion. In my case, mine started rusting in less then a years time. I'm not too concerned about it, afterall, they are a budget header so I can't expect the world. One day I hope to upgrade to Kooks and a true dual setup.
Old Feb 6, 2007 | 01:49 PM
  #36
CamaroRacing12's Avatar
when did u buy ur pacesetters?
Old Feb 6, 2007 | 02:06 PM
  #37
2000GTP's Avatar
I would like to say I bought them in July of 2005.
Old Feb 6, 2007 | 02:31 PM
  #38
Critter's Avatar
i bought mine in aug of 2006 and have driven 3500 miles and mine are showing signs of rust also
Old Feb 6, 2007 | 08:33 PM
  #39
budget headers...AMEN. for me, this is all budget. when i can afford it, ill get some kooks. and maybe a vette.
Old Mar 14, 2007 | 01:24 PM
  #40
anyone have or know where i can get a detailed write up of the install?
Old Mar 14, 2007 | 03:07 PM
  #41
2000GTP's Avatar
Teke184 has a guide on his Cardomain for a header install on an LS1.
Old Mar 16, 2007 | 02:07 PM
  #42
jarheadjim's Avatar
I would add poly motor mounts to your parts/install list. I installed them on my 98z at the same time I installed pacesetter LTs and ORY, and I have not had any issues with the Y pipe banging. Definately worth the extra 50 bucks for the mounts, and so much easier to install when the manifolds are removed.
The pacesetters fit great and tuck up tight. I did not have to remove anything other than the stock exhaust manifolds and the small heat shields on the body to allow for clearance on the install.
As for the tools, swivel sockets and a swivel head ratchet are worth 10x their weight in gold and simplify the install a lot. I also would have a sawzall and torch handy to remove the old and mate the new y pipe up to the existing cat back without mangling it to pieces. Just my .02
Old Mar 16, 2007 | 06:16 PM
  #43
how bad is your vibration with the polly motor mounts?
Old Mar 16, 2007 | 06:19 PM
  #44
2000GTP's Avatar
Some people don't notice much vibration at all, some do it seems. From what I have heard, it is a good idea to replace the motor mounts and tranny mount together with poly and that should play a big factor in reduced vibrations.
Old Mar 16, 2007 | 07:13 PM
  #45
ok. note taken. polly mounts it is. :-)
still have to wait for the weather to break first. g.d. weather.
GREEN3112
Feb 10, 2019 09:19 PM
FredM
Exhaust System
Feb 8, 2016 02:10 PM
football4life
Oct 4, 2015 07:48 AM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
Slayer
Aug 17, 2015 03:55 PM
