Pacesetter LTs
Old Feb 5, 2007 | 02:45 PM
  #16
SpeedDemon02SS's Avatar
pb blaster?
Old Feb 5, 2007 | 02:55 PM
  #17
JoeliusZ28's Avatar
rust penetrant. can be bought at just about any hardware/auto store or walmart.
The stuff is a miracle worker, i have a hard time fathoming how the stuff manages to loosen bolts so well. soak all your manifold bolts and y-pipe bolts wiht it the day before, and an hour before you remove them, and they will come off a TON easier.
Old Feb 5, 2007 | 03:02 PM
  #18
oh...duh. yea.
ok...so my list is this:
Materials:
Pacesetters - coated
y-pipe
02 sims
02 extensions
ARP header bolts
better gasket - how is the pacesetter one bad? arnt the all the same stuff?
NKG-55 plugs - why not, i have them off anyway.
New wires - same as above.
Tools:
couple beers
Various Sockets
Torque wrench
various open ended wrenches
another case of beer
some mallets
jacks
jack stands
more beer
pry bar - 2x4 for movign the motor
BFH - for when the tough get going
shot of whiskey
and bandaides
have i missed antyhing i my lists? not too bad for 700 bux.
Old Feb 5, 2007 | 03:08 PM
  #19
JoeliusZ28's Avatar
that looks good if you arent going with locker bolts, and yes you need better gaskets. the paper ones that come with pacesetters are junk. i used fel-pros and have had no problems. my friend reused his stock manifold gaskets, but his car was only 40k miles. oh and you also are gonna need at least one 3/8" universal joint.
Old Feb 5, 2007 | 03:19 PM
  #20
what is the difference between the ARP bolts and locker bolts? i thought the ARP were locker bolts.
I'll get a new gasket, not worth screwing up the job for a $30 gasket.
Old Feb 5, 2007 | 03:28 PM
  #21
JoeliusZ28's Avatar
im not sure if ARPs are lockers or not, i was under the impressiion they were basic header bolts. the breslins i have have an allen screw in the head that you turn the opposite direction to lock the bolt in the head.
Old Feb 5, 2007 | 03:51 PM
  #22
2000GTP's Avatar
The ARPs are a non-locking, stainless steel bolt.
Old Feb 5, 2007 | 03:58 PM
  #23
95LT1conv's Avatar
and Breslin is out of business
Old Feb 5, 2007 | 04:00 PM
  #24
JoeliusZ28's Avatar
dang, thats a news flash!
Old Feb 5, 2007 | 06:56 PM
  #25
2000GTP's Avatar
From what I've heard, Summit and Jegs may still have some quantities if you call and ask. Otherwise, it looks like Stage 8 is the "go-to" company for locking fasteners.
Old Feb 5, 2007 | 09:45 PM
  #26
ok...so...stage 8 or ARP?
Old Feb 5, 2007 | 09:58 PM
  #27
95LT1conv's Avatar
like i said earlier, unless you want to spend $100 on a set of studs, then go with the stage 8
Old Feb 6, 2007 | 07:39 AM
  #28
2000GTP's Avatar
I would do the Stage 8s over the ARPs.
Old Feb 6, 2007 | 08:15 AM
  #29
personally, i would like to save a few bux, thats why i am going with the pacesetters over kooks.
Old Feb 6, 2007 | 08:22 AM
  #30
2000GTP's Avatar
The Pacesetters are still a good set of headers, not nearly a match for the Kooks quality, but still a good value for the price. The coating is kind of a hit or miss though, for some it lasts a long time, for others like myself, it starts to rust in less then a years time.
