Pacesetter LT/ORY with 2.75 catback - how bad?
Old May 19, 2007 | 09:56 AM
JP95ZM6's Avatar
I'm planning to use those LTs and ORY with the stock catback pipe and my Flowmaster 80 series crossflow muffler, for a while at least. Stock pipe because I can't find just a 3" intermediate pipe available for sale, only full catback systems. I want to run the Flowmaster because I love the sound, and I have read here it only costs maybe 1-3 HP. I'll be around the 400 RWHP level.
Questions:
How much power will I give up using the 80 series with 2.75" (stock) intermediate pipe?
How much better would the 3" intermediate pipe be with the same muffler?
If it's a big difference, I'll probably add an E-cutout after the ORY.
Old May 19, 2007 | 02:39 PM
2000GTP's Avatar
Since it does pose a slight restriction to the rest of the setup, I'm sure it will choke you up a bit, but probably not enough to notice or worry about. Put on the 30 dollar cutout and then you can keep the sound of your existing catback and the peace of mind for the track if you are wanting to squeeze out every last bit.
Old May 19, 2007 | 08:21 PM
wildweasel's Avatar
The cut-out is a good idea. I thought about LT's and ORY with a stock exhaust + cutout (kinda makes it a sleeper). Luckily I found an SLP 2OTL on ebay for cheap, so I'll be going that route. It would be nice if somebody would produce a 3" over the axle pipe so those of us without access to pipe benders and welding equipment could fab up our own exhausts.
Old May 19, 2007 | 09:33 PM
ricehammer's Avatar
Check these intermediate pipes out.
http://store.summitracing.com/partde...5&autoview=sku
Old May 20, 2007 | 06:33 PM
JP95ZM6's Avatar
ricehammer, thanks for the links. I found those, too, but they are listed for the LS1 cars only, 1998 and after. Nothing comes up in a search for my 95 but a 2.5 inch intermediate pipe.
Old May 20, 2007 | 06:58 PM
mdacton's Avatar
the slowmaster is a bigger problem than the pipe
Old May 20, 2007 | 07:15 PM
JP95ZM6's Avatar
I guess that puts it in perspective. Not so bad a tradeoff on the pipe, then. Thanks.
BLK1997Z28
May 7, 2015 03:01 PM
drptop70ss
May 4, 2015 08:22 PM
Ringmaster72
Apr 2, 2015 08:32 PM
WildRidez
Mar 27, 2015 08:22 AM
KASR_Z28
Aug 6, 2002 03:34 PM
