pacesetter longtubes
Old Mar 1, 2007 | 04:08 PM
FAST96Z's Avatar
whats up just wondering if anyone has put this setup on a 96 z28 pacesetter longtubes,y-pipe,borla cat back if so any opinions on sound and how much of a bitch its going to be. i have a lift so hopefully that helps and im getting the headers and the ypipe from pacesetter what if any modifacations are needed to bolt this up thanks for the help and if anyone knows the best or better way to go about taken the factory manifoold off let me knoe later
eric
Old Mar 1, 2007 | 04:12 PM
2000GTP's Avatar
Plenty of people on here are using the Pacesetter LTs and ORY, but choice of catback varies. Its not a job that requires alot of mechanical know-how, but it does require patience and some time. A lift will help out drastically as well. It wouldn't hurt to do a search, there are plenty of posts covering the actual install and tips and tricks to make it go smoother. Since your car is a 96 and has rear 02 sensors, the Pacesetter ORY will completely eliminate any usage of the cats so you will either need 02 simulators or PCM tuning to prevent an SES light. Also, if you get the headers that do not have the emissions fittings (AIR and EGR), you will need EGR blockoff plates and you will need PCM tuning to edit out those two systems.
Old Mar 1, 2007 | 05:17 PM
mrmint69's Avatar
I got my mids and they came with a nice copper gasket but the flange gaskets look like cheap paper. I bought a set of 2 1/2" copper ones on Ebay for $10 with the embossed. Other than that i have everything i need and i have to figure out how to get the welded cat to fit the new Y pipe. Any ideas?
Old Mar 5, 2007 | 01:52 AM
Z-RATED94's Avatar
Squirt all the bolts with some Liquid Wrench or something along those lines. If you have the time do it a couple of days in advance, and do it a couple of times. Once your done with the install make sure you don't have any wires or anything else to close to the headers or y-pipe. If you do, some zip ties can be really handy at solving that problem. Also watch how your spark plug wires are, so that you don't burn any. Check where the y-pipe is compared to the fuel lines and use some heat shielding tape to protect the fuel lines. Also if the zip ties don't pull any of the wires away from the headers enough, put some heat shielding tape on those also. Good luck, and take your time.
GREEN3112
Feb 10, 2019 09:19 PM
football4life
Oct 4, 2015 07:48 AM
tdigger9899
Sep 7, 2015 10:56 AM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
97SSdude
Aug 21, 2015 09:36 AM
