pacesetter gaskets...
Old Feb 25, 2007 | 11:12 PM
reamo04's Avatar
are the ones that come with the headers alright to use? or should i spend the $35 on fel-pros?
Old Feb 26, 2007 | 12:46 AM
sonia93's Avatar
I was wondering the samething
Old Feb 26, 2007 | 12:58 AM
69gto96z's Avatar
Buy the fel-pros. But get em from thunder racing, they are only 20 bucks there.
Old Feb 26, 2007 | 02:07 AM
mrmint69's Avatar
I read some where they are kevlar material. I bought a set of copper for $20 just to be safe. I would assume they are nothing fancy and would do the job. I always like bumping the quality up a notch.
Old Feb 26, 2007 | 08:05 AM
2000GTP's Avatar
They are junk paper gaskets. When I took delivery of the headers, those went straight in the garbage and a box from Summit containing Fel-Pro 1406s was shortly on the way.
Old Feb 27, 2007 | 10:47 PM
sonia93's Avatar
copper ones came with my pacsetters what about them?
Old Feb 28, 2007 | 03:56 AM
mrmint69's Avatar
It sound like from reading old posts the key to successful sealing is locking bolts or go in every so often in the first 1000 miles and retighten them and they should be good to go with no further checking needed.
Old Feb 28, 2007 | 10:46 AM
2000GTP's Avatar
Copper is generally a preferred gasket material. I didn't know Pacesetter started using copper gaskets, I guess they received more complaints about their previous paper gaskets then they wanted to hear.
Old Feb 28, 2007 | 03:54 PM
Ratlor's Avatar
I just got some Pacesetter longtubes and they came with copper gaskets. I wish I would have known this before I bought my Percy's seal4good, but it's all good, i'm glad to have bought quality from the get go.
Old Feb 28, 2007 | 07:05 PM
Projectz28's Avatar
Moderator
if they are now comming with copper then just use them. If not then get the felpros and ARP 1" 12pt bolts. I've used this combo several time with no problems. But as mentioned you should check em after the first heat cycle and every so often for the first few hundred miles.
Old Feb 28, 2007 | 07:12 PM
FastLt1's Avatar
I bought percy dead alumninum. Haven't put them on yet.
Old Feb 28, 2007 | 09:45 PM
Jared 3870's Avatar
My pacesetter longtubes just came in today and they have copper gaskets as well. Pacesetter must have finally wised up.
Old Feb 28, 2007 | 09:53 PM
reamo04's Avatar
man, i just ordered fel-pro gaskets too
Old Feb 28, 2007 | 10:22 PM
mrmint69's Avatar
After reading the post on them coming with cheap paper gaskets i orders the copper ones for 20.00. I received the mid's today and they had the ones with the kit and the ones i ordered, both being copper. The ports on the header are a little larger than the stock headers so when i stuck the $20 gaskets over the headers they were much smaller almost a 1/4" top to bottom. If i used anything but the ones for from the kit they would not seat properly. They both have the raised lip and if i bolted the $20 ones on they would not even touch the header so the seal would not be good. The ones in the kit line up dead perfect and should be dead perfect. After all is said and done i will return the ones i bought and use the kit gaskets. Hope this helps someone out. Now all i have to do is install them!
GREEN3112
Feb 10, 2019 09:19 PM
FredM
Exhaust System
Feb 8, 2016 02:10 PM
football4life
Oct 4, 2015 07:48 AM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
Slayer
Aug 17, 2015 03:55 PM
