not happy with magnaflow
Old Jul 23, 2008 | 11:48 AM
  #16
6Speed's Avatar
Borla sounds like **** with the open plate. It's not going to solve your problem.
Old Aug 12, 2008 | 08:55 PM
  #17
97BlackSSCamaro#142's Avatar
Originally Posted by 97BlackSSCamaro#142
i have a similar setup...stock manifolds, Stainless works o/r y-pipe,,,dynomax bullet res. instead of cat,, and a magnaflow muffler , with the 2otl outlet and single inlet,,,,,
just throw a bullet and it will sound fine,,,alot less popping and cracking with the bullet
so what exactly would it sound like without the bullet,,,so i would run just the offroad y-pipe and the magnaflow muffler
im tempted to take the bullet off
Old Aug 12, 2008 | 09:05 PM
  #18
ZELIMINATOR-28's Avatar
I have stock mani's, a gutted cat and a magnaflow and it sounds ok. It is a bit raspy on hard accel but I think it sounds cool. Still I think I am gunna put a flowmaster 40 on there, and some long tubes.
Old Aug 12, 2008 | 09:07 PM
  #19
i had a flowmaster 40 on mine previous to the magnaflow ,,the mag sounds alot better than the flow
Old Aug 13, 2008 | 02:14 PM
  #20
wrd1972's Avatar
Originally Posted by slomarao
get a small bullet muffler in place of the cat if you dont want the rasp. It will help out lots, or you could run a cat again, your choice.
I did this and the bullet muffler failed in 6 months from the extreme heat just post manifolds, or in my case headers. The insides started deforming, then it fell apart.
Running no cats makes some rasp. Its not the magnaflow. Even my Borla had some without cats.
Old Aug 15, 2008 | 07:46 AM
  #21
mzgp5x's Avatar
I destroyed my cats running a D1 on 383ci LT1. Removed them and ran 2 1/2 straight thru pipe. Lots of bad resonance @ 2k to 2.5k rpm on a Spintech 3 1/2 muffler. Could not live with it. I did a 3 1/2" cc 3-disc insert in the pipe before the axle. No more resonance and did lower the noise. I still open 3 1/2" qtp when I need to for max flow.
Old Aug 15, 2008 | 09:53 AM
  #22
chris8835's Avatar
I have LT's, Off road Y-pipe and a Magnaflow cat back and I like the sound of it but it is just not as loud as I expected it to be. Maybe I am just used to hanging around to many Mustangs.
Old Aug 16, 2008 | 11:31 AM
  #23
i took off my bullet resonator thursday ,,it sounds about the same as before just alot louder
Old Aug 26, 2008 | 07:18 PM
  #24
JMG97SS's Avatar
Definatly dont go Borla if you dont want rasp. I just did LT's, no cats, on Borla and it is LOUD and raspy at 2000-2500 rpm range. Im looking to add a bullit muffler of just change to something else.
Old Aug 26, 2008 | 11:50 PM
  #25
danhr's Avatar
this thread keeps getting resurrected from the dead over and over and over and over.....
Old Aug 28, 2008 | 01:58 PM
  #26
Bayer-Z28's Avatar
Originally Posted by Bluovlh8er
it sounds like ***, its not loud enough and raspy...
stock manifolds, no cat...
im about to buy the borla, but is there a huge difference in sound? im prolly gunna run open plates
If you're complaining about raasp w/ no cats on a Magnaflow, you'll hate the Borla.. I had one for years.. LT's ORY w/ no plate and it was all rasp..
Old Aug 28, 2008 | 02:11 PM
  #27
Jazsun's Avatar
People who complain about rasp on a free flowing exhaust are just dumb..its the nature of the engine. Go throw some parts on to help restrict power if you dont like rasp.
Old Aug 29, 2008 | 12:00 AM
  #28
danhr's Avatar
my kooks/gmmg doesn't have much rasp... I don't think it's restrictive?
Old Sep 5, 2008 | 08:15 AM
  #29
2000GTP's Avatar
Just add some LTs to the mix, then you'll have no rasp.
Old Sep 5, 2008 | 11:05 AM
  #30
Jazsun's Avatar
^ LT's and magnaflow sounds awsome
