Need help with o2 sensor
Old Nov 10, 2008 | 04:54 AM
cmking26's Avatar
I had a CEL and autozone said it was o2 sensor bank 2. My car is an 02 and only has the two front o2's in the header collectors. I pulled the passenger side o2 and it has about 16" of wire. The new one at autozone, Bosch 13444, has a shorter wire. Is this normal or is it a problem? Do I need the longer 13111?
Old Nov 10, 2008 | 01:46 PM
Green96Z's Avatar
So you have an ORY and no rear O2s? Did you have them edited out in the PCM? If you are going to replace an O2 I would recommend going with AC Delco.
Old Nov 10, 2008 | 03:50 PM
cmking26's Avatar
Yes no cats the rears are tuned out. Which Delco one do I need? pn
Old Nov 10, 2008 | 07:52 PM
Green96Z's Avatar
Left should be 19178928, right is 19178921. I think they have different part #s because of different length harnesses.
Old Nov 10, 2008 | 08:06 PM
cmking26's Avatar
So for my passenger side if I used Bosch do I need 13444 or 13111? Thats kinda what Im looking for, the length between the two. I have longtubes and just dont want to order short ones.
generaldave
Sep 25, 2015 06:48 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
