Magnaflow cat-back
Old Dec 31, 2008 | 08:54 AM
Irock_89's Avatar
Magnaflow cat-back
hi i got a 89 iroc with a 350 sbc and im lookign at getting a maganflow catback for it. i recently found a deal on a 4 th gen magnaflow cat-back and was wondering if it's the same as a 3rd gen? would it sound different since it was made for a 4th gen with a LT1, LS1?? thanks
Old Dec 31, 2008 | 09:25 AM
firstlast's Avatar
it should fit, and it will be a different motor so it will sound a bit different
Old Jan 5, 2009 | 07:41 AM
teke184's Avatar
basically the only difference will be the front of the I-pipe where it connects to the merge on the Ypipe. you'll probably need the S pipe that SLP use to make to get it to mate up. or have a good shop do it out of some U bends. nothing major.
only other thing would be a minor difference in the mounting brackets on the back of the system.
the sound will vary a little due to different motors, but the performance will be the same.
Old Jan 6, 2009 | 06:49 AM
TPeye's Avatar
Magnaflow makes a catback for the 3rd gen cars. I have the dual converter exhaust and it took some work (adding pipe, expanding magnaflow supplied pipe) to get it to fit. Here is where I got mine http://www.hottexhaust.com/detail.asp?PRODUCT_ID=16829
marlar98
Oct 21, 2015 02:02 PM
Fatdog2
Sep 26, 2015 12:06 AM
JJOHNROE
Sep 8, 2015 05:39 PM
SSCAMARO1659
Aug 30, 2015 08:45 AM
