(LT1) MAC mids and oil cooler
Old Jan 22, 2007 | 07:30 AM
SnakeOiler's Avatar
Yes, there are lots of threads about MAC mids, but I can't find any that talk about interference with the stock oil cooler.
Has anybody run into this problem? I am mocking up everything on my engine stand and I already have made some O2 extensions for these pipes. How do I get around the cooler pipe interference? Just don't use it?
Looks like even if I don't use the cooler, it's just going to defeat the purpose of the cooler anyway, because it is so close to the coolant pipes.
Comments, thoughts?
Old Jan 22, 2007 | 09:30 AM
Gripenfelter's Avatar
Never had a problem with the piping on the 95s I worked on. You can also just remove the oil cooler too. They can get clogged up with engine assembly lube and can starve your motor of oil.
Old Jan 22, 2007 | 09:41 AM
BUBBA's Avatar
DX the cooler. JMHO
Old Jan 22, 2007 | 09:45 AM
Brent94Z's Avatar
Super Moderator
I had Mac mid lengths and the oil cooler on my 94. No problems...
http://www.bfranker.badz28.com/fbody/exh-0665_IMG.JPG
Old Jan 23, 2007 | 10:35 PM
SnakeOiler's Avatar
Well, now that I actually had time to bolt the cooler and pipes on, I see that there is no interference. But, the exhaust flange is close to the pipes. Hopefully, I'll be bolting the engine back in the car this Saturday.
Old Jan 26, 2007 | 09:09 PM
Z95m6's Avatar
I would just ditch the cooler like a few others have mentioned. It'll help get the oil filter farther away from the header and some people gain oil pressure out of the deal too. I'm glad i removed mine. It made it so much easier when i replaced my oil pan gasket on my Z.
94Z28LS1toLT1
Parts Wanted
Jan 21, 2015 04:37 PM
Jul 4, 2005 05:00 PM
97 RedSS
Jun 10, 2003 07:58 PM
snksknr94
Aug 2, 2002 07:31 PM
Camaro90RS
Jul 23, 2002 07:57 AM
