LT1 Headers
LT1 Headers
Hi there i want to know what are the best long tube headers to put on my 4th gen camaro? mine has the egr and air injectors fitted to both manifolds. Many thanks. Waggyalien
Re: LT1 Headers
Is it necessary to keep the AIR (one per side 94-97) and EGR connections (one on passenger side only, all years) where you live? Do you have either visual, plug-in or tailpipe emissions inspections?
What year is your car? Is it a single-cat (93-95) or dual-cat (95 CA emissions A4's, 96-97)?
Is your engine stock or highly modified? That will affect header selection.
You need to add a "Signature" with basic info about your car - year, model, enginem, trans and any major mods.
"Best" in terms of quality would be the Kooks long tubes. "Best" in terms of cost effectiveness would be Pacesetters. What is your budget? Do you plan to run single or dual exhaust? In any case, plan on getting them with a cera-metallic coating, for improved performance, reduced underhood temperatures, and extended life.
Jul 4, 2005 05:00 PM
