LS1 / LS6 / LS2 / LS7 Exhaust Manifolds
Old Jan 7, 2007 | 05:05 PM
DeanHensler's Avatar
Are they the same for each motor or different?
If different, where can I see pictures of each kind?
Old Jan 8, 2007 | 07:19 AM
Capn Pete's Avatar
LS1's (specific to F-bodies) used one version of manifold from '98 - '00, then a revised (improved) manifold for '01/'02.
The LS7 manifolds are way different than any LS1 manifold.
I have no idea about the LS2 manifolds, since they never came in any F-body ... but as the C5 LS1 manifolds were different from F-bodies', I can only assume that LS2 manifolds would be different as well (and I'm not sure about the ones in GTO's either ).
Old Jan 8, 2007 | 08:56 AM
AL SS590 M6's Avatar
Moderator
Wrong wrong wrong. (specific to F-bodies) 98-99 have the same exhaust manifold. 00 and up are the same.
Old Jan 8, 2007 | 09:02 AM
Capn Pete's Avatar
Sorry!!!
Was 2000 the year that the EGR was scrapped, or was it in '01?? I think (thought? ) that was part of what influenced the change in exhaust manifolds?? (but then I think maybe I've gotten that confused with the LS1 - LS6 intake manifold change???)
Can you confirm which is correct? (about the EGR ... I know that '01/'02 were the years for the LS6 intake) .
Old Jan 8, 2007 | 09:14 AM
Moderator
Sorry!!!
The egr was dumped in 01 with the LS6 intake but the exhaust manifold was left the same as the 00 with the EGR fittings not cast in.
98-99 tubular sheet steel exhaust with LS1 intake and EGR
00 cast iron exhaust with LS1 intake and EGR
01-02 cast iron exhaust with LS6 intake and no EGR
Old Jan 8, 2007 | 01:54 PM
Capn Pete's Avatar
Thanks, that clears up some confusion for me!
69z-28
Jan 29, 2016 10:46 PM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Chris Anderson
Jan 27, 2015 08:30 AM
spearous
Jan 12, 2015 11:03 AM
