lock tight on header bolts????
Old Mar 25, 2007 | 01:36 PM
nightrider93's Avatar
about to start doing a gasket swap on hooker long tubes on lt1. should i put a dot of lock tight on the bolts or leave them bare if i should use lock tight which one blue right????
Old Mar 25, 2007 | 02:15 PM
JimboManJones's Avatar
Just use anti-seize on the bolts. Don't use locktite, just make sure they are tight, and re-tighten them after some heat cycles. Mine never loosened up even after a few heat cycles, don't understand how so many people have problems with header bolts coming loose.
Old Mar 25, 2007 | 02:39 PM
mine cam loose a little but i always checked them but since i am putting on the new gaskets and it is such a pain in the a$$ just tryingt o make it where i dont blow out another set and have to do it again
Old Mar 26, 2007 | 02:51 PM
OBE1 95Z28's Avatar
I agree with the post above, use a small amount of antiseize as your threading steel bolts into an aluminum head. Loctite won't work anyways as the heat of the exhaust would "melt" the loctite.
Old Mar 26, 2007 | 02:54 PM
2000GTP's Avatar
You'll just have to periodically check them if you are worried about them loosening up. Or just opt for a set of locking header bolts.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
