Kooks owners - verify this install (y-pipe)
Old Mar 14, 2008 | 11:35 PM
caldercay's Avatar
I just want to be sure other Kooks users show the same install tolerances.
The y-pipe is *awefully* dam close to the brake lines ... and the y-pipe's exit
is tucked way up into the driveshaft tunnel.
Is this how others are positioned? Just want to be sure.
http://picasaweb.google.com/calder.cay/Kooks
Old Mar 14, 2008 | 11:51 PM
Green96Z's Avatar
Looks about right. I think your driver side tucks up a little better than mine though. Hard to see in my pic (don't have one of the other side).
My y-pipe had about 1/2" of clearance from the tunnel brace, looks like yours is sitting a little high (maybe just the angle?). Either way, it took me a while to align my catback, which is still crooked. I need to have a muffler shop fab me up something so it sits straight.
Old Mar 15, 2008 | 08:36 AM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
I really can't remember and I can't go look. I can say that my Y-Pipe mated right up to my GMMG catback and didn't require any manipulation. The ground clearance was very good.
Is the end of your Y-Pipe angling upwards?
Old Mar 15, 2008 | 09:27 AM
caldercay's Avatar
Yes, it is angling upwards a bit. I dont think it's an issue with mating it to
the catback pipe, but it is tucking up in there. Also, there is less than an
inch of clearance from the y-pipe and the driveshaft.
Old Mar 15, 2008 | 10:12 AM
caldercay's Avatar
Here's four more photos, shot from the back, starting with this one:
http://picasaweb.google.com/calder.c...85485701824210
Old Mar 15, 2008 | 11:37 AM
BTC's Avatar
BTC
I would guess mine probably fit like that. It was definitely tucked up in there. I wish I could go look to confirm, but I can't.
Old Mar 15, 2008 | 04:10 PM
BLDun's Avatar
Mine tucked up in as well. But that's the reason I went this direction. I have much more clearance than I did with the Jet Hots longtubes. I did have to cut some off my "Y" pipe on one side to get it to fit right though.
Old Mar 15, 2008 | 05:04 PM
roguedriver's Avatar
I used some reflective heat foil stuff around the break/fuel lines whre there close to the y-pipe just for some added protection. Wouldn't be a bad idea.
Ken R.
Old Mar 16, 2008 | 12:10 PM
caldercay's Avatar
Ken R.
That's a great idea Ken ... I think I'll get some wrap. The y-pipe did slide right
on, but as can be seen by the photos, the y-pipe is up against the underbelly
on both the driver and passenger sides, so I do want to fab a bracket to
"pull the pipe" down a bit.
BLDun - fortunately, I didnt have to do any customization to the y-pipe. I did,
however, have to grind the header flange in the center on the driver side,
since it wasnt exactly level (it had a slight high spot in the center).
Old Mar 22, 2008 | 04:52 PM
ssbowtie1's Avatar
Ken R.
What is this exactly? Do you have any links?
Old Mar 22, 2008 | 05:04 PM
BLDun's Avatar
Do a google search for exhaust heat wrap or heat tape and you will find lots of places
Old Mar 22, 2008 | 06:13 PM
caldercay's Avatar
Yep - like here:
http://www.heatshieldproducts.com/au...e_products.php
Old Jul 27, 2008 | 09:42 PM
wrd1972's Avatar
How did you attach the round opening of the catalytic converter to the oval opening of the left portion of the y-pipe?
Old Jul 29, 2008 | 08:00 PM
BTC's Avatar
BTC
I don't know if this will answer your question, but I'm pretty sure the cats are welded into the y-pipe by Kooks and would'nt require that you attach them to anything. I can't say definitively because my y-pipe is their offroad version, but my y came in two pieces and joined together well beyond where the cats appear to be placed in that pic.
Old Jul 29, 2008 | 08:10 PM
Green96Z's Avatar
Kooks welds the cats to the y-pipe. The front end of the cat slips over the header collector and is clamped on with the stepped clamps that Kooks supplied.
