Header Questions
Old Oct 3, 2007 | 03:36 PM
CamaroZ2897's Avatar
Header Questions
I have a 97 z28 and I am going to order pacesetter coated lt's with the pacesetter y pipe and get a GMMG exhaust. I'm going to get the headers with emissions and hook up the AIR and EGR but I'm going to get rid of the cats. My question is should I get o2 simulators or just get the o2 senors tuned out when I get a tune? Also will the gmmg exhaust slip fit on the pacesetter y pipe and if not what will I need to do to make it fit? Thanks
Old Oct 4, 2007 | 12:36 AM
Unertl42's Avatar
you might as well just get them tuned out since it won't cost you any more, I wouldn't waste the $ on o2 sims
Old Oct 5, 2007 | 11:34 AM
ok thanks thats what il do. But does anybody know about the gmmg fitting on the pacesetter y pipe?
Old Oct 6, 2007 | 04:12 PM
2000GTP's Avatar
I may be wrong, but it doesn't look like the GMMG has a flange welded at the end of the i-pipe. The Pacesetter y-pipe is slightly oversized so it should slip in assuming the GMMG i-pipe is exactly 3" in diameter.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
