How to replace manifold studs?
Old Feb 12, 2009 | 11:20 PM
reamo04's Avatar
wondering how I would go about replacing the bolts on stock manifolds?
Old Feb 13, 2009 | 01:18 AM
MikeGyver's Avatar
huh?
Just a guess but, unscrew old bolt, screw in new one?
Old Feb 13, 2009 | 01:44 AM
reamo04's Avatar
Originally Posted by MikeGyver
huh?
well, idk, its almost like their stuck in there and spot welded or something...are these reverse threaded perhaps?
Old Feb 13, 2009 | 06:37 AM
Wild Willy's Avatar
Exhaust manifolds? They can be difficult- they tend to rust out. I have had best luck doing them while hot- you need to wear welders gloves, but the heat loosens the corrosion. Otherwise, heat them with an acetylene torch- propane isn't going to throw enough heat- get them glowing cherry red, and they come right out-
If they snap off, take the whole manifold off- there may be enough of a stub sticking out, if you are lucky, to get them out with vice grips- otherwise, it can get real ugly-
Old Feb 13, 2009 | 11:06 AM
reamo04's Avatar
yeah i have them off the car, so that'll be easy enough to do.
Thanks guys.
Old Feb 13, 2009 | 08:42 PM
MikeGyver's Avatar
lmao ohh are you talking about the 3 studs in each manifold? I thought you were talking about the manifold to head bolts...
I replaced the 3 collector studs on both my manifolds since they bent to hell.
I heated up the cast iron around the stud with a vutting torch, and simply unscrewed them with a big crescent wrench.
I used a cutoff wheel on the back side to flatten the shoulder so I could TIG weld the appropriate sized bolt in place, after drilling the threads out.
I also over sized the 3 holes in each collector flange so it slides over the 3 studs/bolts easily without binding.
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
markaubuchon
Jan 14, 2015 01:48 AM
Catmaigne
Dec 25, 2014 12:16 PM
Jul 4, 2005 05:00 PM
