how do i replace the egr valve???
Old Jan 16, 2010 | 10:58 PM
javi805's Avatar
i ned help on how to replace the egr? i scanned it and gave me the code p0400..and i need to replace it?? ned help thanx
Old Jan 17, 2010 | 12:00 AM
Fatdog2's Avatar
Before you spend money and time on this,might spray some carb cleaner into the throttle body.Get the right one though.Then check for codes again.My02.(throttle body cleaner).Hope this helps.
Old Jan 17, 2010 | 12:49 AM
blubird's Avatar
telling us the year and engine might help
Old Jan 17, 2010 | 09:13 AM
SUGGESTION: Add a "signature" with basic info about your car - year, model, engine, trans type and any major mods. That way people have the info they need to answer your questions.
Old Jan 17, 2010 | 11:15 PM
javi805's Avatar
my bad its a 1997 z28 lt1 350cin..thanx fatdog hopefully it works ill give it a try
Old Jan 18, 2010 | 12:27 PM
If you need to replace it, the EGR valve is held on the back of the manifold by two studs. Unhook the vacuum line from the valve. Working blind - remove the nuts (1/2" wrench) from the studs, and pull the valve off the studs - may take a bit of leverage. Make sure you get the old gasket off as well. Reverse steps to install, using new gasket that comes with the EGR valve.
Courtesy of Shoebox:
http://shbox.com/1/egr1.jpg
Old Jan 19, 2010 | 05:24 PM
javi805's Avatar
Thanks it ill try this thanks alot
HectorM52
Jul 30, 2017 11:46 AM
edman
Mar 13, 2015 09:39 PM
jocamino
Dec 29, 2014 10:15 PM
Jazsun
Dec 29, 2014 12:14 PM
