High flow Cat? With mid headers & Magnaflow
Old Feb 22, 2007 | 02:52 PM
mrmint69's Avatar
I am putting a set of mid Pacesetters on soon. I have the magnaflow exhaust. Summit has the high flow cat for 214.00. Is it worth the money to add this or just a waste of time. Does the exhaust need back pressure to run right or is less restrictions good? My car has 100k miles so is the cat a good idea to replace now since im dong this and would a factory replacement work better for me? I have pretty strict emissions here.
Old Feb 22, 2007 | 02:56 PM
2000GTP's Avatar
If you have emissions, I would defintely run a cat. I'm a firm believer in if it ain't broke, don't fix it. Since you already will have the exhaust apart anyhow, it probably wouldn't hurt to throw a fresh cat on there as well.
Old Feb 22, 2007 | 05:55 PM
Z95m6's Avatar
Just go to ebay and check them out. You can get MagnaFlo's for $65 shipped i think. Here is one i found. http://cgi.ebay.com/ebaymotors/Magna...90813367QQrdZ1
The part number most people use is the 94009
Old Feb 22, 2007 | 08:49 PM
Greed4Speed's Avatar
If your headers are true mids, then stock replacement cats wouldn't work. Just get some Magnaflow/Carsound cats w/out the AIR tube. You'll also need to get a Y to work with mids. Are you sure they're not shorties?
Old Feb 22, 2007 | 09:42 PM
mrmint69's Avatar
Here is the summit site. http://store.summitracing.com/partde...5&autoview=sku
Thanks for the ebay tip. This will save some bucks for other mods.
Old Feb 23, 2007 | 05:57 PM
mrmint69's Avatar
What would it take to just put straight pipe in there and when emission comes due put the cat back? Is there a bolt in that would easily go in and out?
Old Feb 23, 2007 | 06:59 PM
2000GTP's Avatar
You would have to rig up your y-pipe and your test pipe and cataytic converter so that they all have flanges. Then you can swap them back and forth with ease. To be honest though, a high-flow cat will cost you little to no power so it might just be easier to go that route.
Old Feb 25, 2007 | 09:48 PM
Jeff H's Avatar
You can get some 3" cats from www.Pypesexhaust.com for under $80 I believe. I put a Pypes cat on my driver's side and a basic Catco 3" cat on the passenger side. It worked well. Here's a picture of the dual 3" cats I added to my Pacesetter ORY.
Old Feb 26, 2007 | 08:08 AM
2000GTP's Avatar
Yeah, I got a pair of Pypes mini-cats for 130 shipped to my door.
alex5366
Mar 8, 2015 11:32 AM
jeff94z28
Sep 11, 2002 02:01 PM
blue89iroc
Jul 26, 2002 04:56 PM
blue89iroc
Jul 18, 2002 04:41 PM
blue89iroc
Jul 18, 2002 03:35 PM
