header install?
Old Feb 24, 2007 | 03:25 PM
sonia93's Avatar
header install?
I was wondering if anyone can tell me the easiest way to install my pacesetter longtubes are there any tricks I need to know?
Old Feb 24, 2007 | 03:42 PM
landstuhltaylor's Avatar
go to zmydust.com, it has a good writeup
Old Feb 24, 2007 | 03:47 PM
pattracing212's Avatar
no matter who you listen to it is still a find out while you go type thing...all of the write ups were a good basic platform but i still had to do a few things differently. i put in shorties but still had to lossen up the motor mounts on each side one at a time to angle the motor. jsut take your time and make sure you keep track of everything that you take off. give yourself plenty of time for error. i started on a friday so i would have all weekend to do it. buy a lot of liquid wrench and band aids. your gonna need it.
Old Feb 24, 2007 | 04:05 PM
soontobeGN's Avatar
Don't try to tighten the bolts using and air ratchet, ask me how I know...
Old Feb 24, 2007 | 05:18 PM
2000GTP's Avatar
My best tip would be to soak all of the old manifold bolts with PB Blaster for a couple of days before touching them with a socket wrench.
Old Feb 24, 2007 | 06:38 PM
CamaroRacing12's Avatar
yea dude make that more like a week ..... i know for damn sure im gonna take my time! in about a month when it starts getting warmer out up here in the northeast im gonna go at mine!.... how hard is it to loosen the motor mounts and tilt the engine??
Old Feb 24, 2007 | 07:28 PM
its really not that hard at all....there are obviously two places where you can loosen them....either n the motor or the chassis. i found it easier to loosen the bolts on the chassis. i used a two by four on a jack under the oil pan. i was skeptic of jacking it up there but if you take your time and disperse the weight evenly throughout it, it works fine
Old Feb 24, 2007 | 10:19 PM
hmmm.... i'll have to think about it...either loosen the motor mounts and tilt the engine or try to slip the headers in without tilting the engine.... i dn.... maybe i will replace the motor mounts all together...how much r some brand new mounts neways??
Old Feb 24, 2007 | 11:23 PM
sworaz
Guest
Posts: n/a
Me and a friend just did pacesetter lt's on my 95 TA. With a lift- we installed both from the bottom of the car after taking apart the steering knuckle, and taking out a couple spark plugs on both sides. The biggest pain was getting the bolts in and out.
Old Feb 25, 2007 | 07:17 AM
2000GTP's Avatar
That is actually the time I spent soaking mine. Some people may have thought I was crazy but I didn't break one bolt and every single one came out with little to no effort. As for the motor mounts, it isn't that difficult but it is one step I didn't have to do. By popping off the passenger valve cover, I gained the little bit of clearance needed to slide the header in.
Old Feb 25, 2007 | 11:08 AM
maybe i will try that b4 i go ahead and try to tilt the engine lol... thx man
Old Feb 25, 2007 | 11:15 AM
2000GTP's Avatar
Yep, alot easier in my opinion to pop the valve cover.
Old Feb 25, 2007 | 08:54 PM
Critter's Avatar
pull the valve covers, steering linkage, put it on jack stands and put them both in from the top. it has to be in the air though or the primary's will hit the floor becuase of the angle you have to put them in from the topbefore lining them up with the bolt holes.
Old Feb 25, 2007 | 09:41 PM
while i have the covers off...what can i do to help out my springs and heads etc? also how do u unhook the steering linkage??.... also with this method will they slide in fine? and at what angle do u have the headers to slide them in?
Old Feb 26, 2007 | 04:59 AM
Bayer-Z28's Avatar
CHeck my Cardomain page or Teke184's page. I used his walk thru. Too much to write up. And yeah, take the coil packs off on the pass side.
I did mine on ramps. Just get that car sky high. Unless you have access to a lift. CHeck www.installuniversity.com or www.ls1howto.com
Mine. Walkthru 1/3 way down
http://www.cardomain.com/ride/463707/2
Teke's.
http://www.cardomain.com/ride/243722/11
EDIT: Disregard. You've got an LT1. Our tips might not help.
