Heat Shield Removal and Reinstall
Old Mar 26, 2021 | 08:05 PM
  #16
1994-LT1-Eric's Avatar
Re: Heat Shield Removal and Reinstall
Finally got the heat shields reinstalled. You can use a
⁵/³²" drill bit and #10 drive rivets. Closer to recommended hole size would be a #27 drill bit, but we got close enough.
The tabs took a ³/¹⁶" stainless steel blind rivet (pop rivet). I should be ready to install these, with 2022 Remflex exhaust manifold gaskets on my next days off cycle. I chose them over felpro 1406 due to their crush/sealing attributes.
Old Mar 26, 2021 | 08:31 PM
  #17
DrewHMS97SS's Avatar
Nicest looking set of manifolds, ever.
Old Mar 26, 2021 | 08:44 PM
  #18
Haha, thanks, not bad for factory restoration. Took me awhile to get them ready, having to spec out the proper fasteners. Should seal up nicely and correct my fuel rich condition.
I have new AC Delco O² sensors, but I'm thinking of running my old ones for a few thermal cycles as a caution of any loose ceramic coating fouling out the new ones. Once they've cooked a bit and blown out all the particulates, was gonna install the new O² sensors.
Thoughts?
Old Mar 27, 2021 | 08:30 AM
  #19
I have also heard of this issue. I just passed 500 miles on my new build with fresh headers and because of the ecu swap, had to use a new wide band o2. So far I am still getting good readings on the o2. I’d say play it safe since you have the option if you believe the old sensors were functioning.
Old Mar 27, 2021 | 05:13 PM
  #20
That's true, having something in there for a few thermal cycles won't matter much I guess, cause the fuel trims will re-adjust I'd imagine when I install the new O2s.
Phoenix'97
Nov 14, 2020 09:16 PM
Mizz96Z28
Feb 14, 2012 11:31 PM
jtblckmaro
V6 Tech
12
May 28, 2006 04:21 PM
92/95TransAm
Jun 2, 2005 09:15 PM
Highlander
Jun 14, 2003 11:42 AM
