Header Gaskets
Old Dec 16, 2006 | 06:35 AM
SROACH's Avatar
Header Gaskets
I ordered a set of Jet Hot LTs/y-pipe from Maryland Speed. Just wondering what is the best header gasket to use.
Old Dec 16, 2006 | 07:14 AM
Schweet97Z's Avatar
Perceys Dead Soft gaskets are the best IMO. I used mr gasket, copper, and felpro and they all blew out on me or didnt seal from the beginning. and btw im going to send you an email when i get more time
Old Dec 16, 2006 | 07:25 AM
SROACH's Avatar
I will check the Perceys gaskets. Do you have a part #? Send me a e-mail.
Old Dec 16, 2006 | 08:41 AM
seawolf06's Avatar
Yes, please list the part number for those. Not to steal your thread, but if anyone can list the felpro part number as well, that would be great. Thanks.
Old Dec 16, 2006 | 09:01 AM
mdacton's Avatar
I have had good luck with fel-pro 1406's
been using the same ones for 4 years
Old Dec 16, 2006 | 09:06 AM
2000GTP's Avatar
I haven't had any problems with the Fel-Pro 1406s either. They are a good gasket set and not very expensive.
Old Dec 16, 2006 | 09:27 AM
96capricemgr's Avatar
Earl's Pressure masters, $40 the first time then $25 for replacement seals to go inside the framework, not cheap but cheaper than trying a bunch of cheaper options and having them fail.
Old Dec 16, 2006 | 10:46 AM
Mean Green's Avatar
I've had good luck with a copper gasket and using some Walker exhaust sealant on them. the exhaust sealant is a bit messy, but I've used this on probably a hundred cars over the past 4 years and have seen no complaints.
Old Dec 16, 2006 | 08:01 PM
SROACH's Avatar
I got the Percys brand from Autozone for $40.00. The guys who work there told me to just put 2 paper gaskets to together on each side. I thought was a little odd.
Old Dec 16, 2006 | 10:53 PM
camarozz95's Avatar
I used the percy's they worked great
Old Dec 17, 2006 | 02:27 PM
95LT1conv's Avatar
i just replaced my set of Percy's with the felpro 1406's. the Percy's were smaller than the exhaust ports on stock heads.
Old Dec 18, 2006 | 06:19 AM
Schweet97Z's Avatar
PHP-66031 is the summit part number. i also got mine from autozone.
Old Dec 18, 2006 | 10:23 AM
byrons1502's Avatar
i tried the summit brand and seem just as good, even using them on old crappy bbc swap meet headers.
Midnight_Z
Feb 16, 2016 09:36 PM
dylan1303
May 22, 2015 12:24 PM
4586
Apr 29, 2015 01:43 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
rick350
Mar 16, 2015 02:59 PM
