Header Bolts
Old Feb 11, 2007 | 08:40 PM
taylorcrzy's Avatar
Header Bolts
Just wondering which header bolts to order? I have the Pacesetter LT Headers and just need some good bolts. I was looking at these from jegs. The part number is 070-612-1000 and the site is http://www.jegs.com/webapp/wcs/store...49575_-1_11721
What do you guys think. Is that the right part number? Oh almost forgot my car is a 95 LT1 Trans Am.
Old Feb 11, 2007 | 09:21 PM
Mauiguyy911's Avatar
Heres the link for the ones that other ppl have told me to use and i also have a '95 LT1 with Pacesetter LT's. Although the ones you listed could work also, not sure:
Stage-8 Locking header bolts:
http://www.jegs.com/webapp/wcs/store...49275_-1_11673
ARP header bolt kit:
http://www.jegs.com/webapp/wcs/store...44888_-1_11673
Sure someone else will chime in on this one though also as im still figuring this out also
Old Feb 12, 2007 | 12:05 AM
martha stewart's Avatar
I just reused the stock ones. Worked great for me!
Old Feb 12, 2007 | 07:31 AM
MysticTeal95Z28's Avatar
I have some 3/4" Stage 8 Lockers still new in the box if you would want them. I could probably make you a good deal on them. Let me know.
Old Feb 12, 2007 | 08:20 AM
Greed4Speed's Avatar
Reuse your stock bolts.
Old Feb 12, 2007 | 11:14 AM
2000GTP's Avatar
I would go with 1" Stage 8 lockers personally.
Old Feb 12, 2007 | 08:31 PM
Bayer-Z28's Avatar
Same here.. I re-tightened/checked them every once in a while. But after about 1000 miles, they've made them selves at home in there. No problems in 2 years.. w/o locktite either.
Stock bolts also depends on the header flange thickness. if it is thicker than stock, you should order the ARP's. -Good brand BTW..
Old Feb 13, 2007 | 05:14 PM
So, pretty much if you have Pacesetter's than the stock bolts wont work too well since the flange is so thick...What length are the stock header bolts 3/4"?
Old Feb 13, 2007 | 05:19 PM
2000GTP's Avatar
I believe the stock length bolts are an inch in length, but they also have spacers on them that suck up about a 1/4 inch of the thread.
Old Feb 13, 2007 | 05:20 PM
Yeah, that sounds about right.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
maybe2fast
Mar 16, 2015 09:45 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
