H pipe instead of the common X?
Old Feb 13, 2007 | 11:35 PM
Jared 3870's Avatar
I have heard that to use a summit X pipe with pacesetters for true duals, it takes a fair amount of fabrication (hits floorpan). Then i got to thinking about summits universal H pipe, and that it looked like i might be able to make it fit better. Any thoughts?
X Pipe Link
http://store.summitracing.com/partde...5&autoview=sku
H Pipe Link
Old Feb 14, 2007 | 06:42 AM
teke184's Avatar
i don't see why it would be much different. it all depends on how the collectors are situated and how you route the pipe off of each one. assuming the same size pipe...i doubt there is much less fab work with an Hpipe.
Old Feb 14, 2007 | 01:31 PM
Jared 3870's Avatar
I think I am going to try the H pipe, just for the sake of doing it. I see everyone using the X, but no one ever uses the H. I think I'll give it a shot.
Old Feb 15, 2007 | 08:00 AM
teke184's Avatar
thats because the Xpipe makes more power due to scavenging
Old Feb 15, 2007 | 08:24 AM
Greed4Speed's Avatar
Its a matter of a couple of HP at most. You'll never feel the difference.
Old Feb 15, 2007 | 05:25 PM
reamo04's Avatar
my buddy jeff has the flowmaster merge-kit on it, its more of an h-pipe than an x-pipe.
Also, h-pipes have a deeper tone IMO
is what I will be using
Old Feb 15, 2007 | 08:46 PM
You do that kit, you might as well get an X-pipe. IMO, the bonus to an H set up is that you don't have to plumb both sides into the center, then back out. That kit still requires you to.
Like I said, X vs H is minimum just like mandrel vs. pressure bent. Its really just a matter of 5 hp at the most but mandrel is the big thing now days. Makes you wonder how fast cars could run with full pressure bent exhausts and H-pipes before everyone was mandrel crazy.
Old Feb 15, 2007 | 09:16 PM
reamo04's Avatar
that kit I am using will allow me to have the sound of the h-pipe, and let me keep everything tucked up nicely
Old Feb 16, 2007 | 11:29 AM
Critter's Avatar
h pipes help below 2000 rpm and make a deeper sound
x pipes help across the board and make a more high pitched mustang cobra sound.
h pipe does nothing other than change the exhaust note. go x
Old Feb 16, 2007 | 11:35 AM
jsetzer's Avatar
My true duals are custom made, so we just added an h pipe close to the collectors to help balance things a bit.
G-BODYT56
Jan 14, 2022 11:14 PM
n2oblkz
Oct 12, 2015 01:53 AM
football4life
Oct 4, 2015 07:48 AM
Ks0209
Oct 1, 2015 07:32 AM
greenzee28
Sep 25, 2015 04:29 PM
