Exhaust System Interchange
Old Feb 7, 2008 | 04:02 PM
wpjdoc's Avatar
Question Exhaust System Interchange
I have a stock cat-back system from an 02 Z28 and was wondering if it would fit a 94-95 Camaro with six cylinder? If so ,what needs attention?
Also, what would be a good price? The system is complete with 35,000 miles on it and in good condition.
Old Feb 7, 2008 | 08:21 PM
Kaj's Avatar
Kaj
I don't think it will work, I believe the y-pipe is different, hangars, etc.
Old Feb 8, 2008 | 07:19 AM
teke184's Avatar
hangers are slightly different...but any good shop can fix that.
and you'll need to get an "S" pipe connection to run from the Ipipe on the catback, to the end of the Ypipe.
on the later models...96+ i think...the ypipe merged and connected to the Ipipe along the centerline of the car. earlier models had the ypipe merge and join the Ipipe on the passenger side (due to having only 1 cat), then the Ipipe curved in towards the centerline, then ran back.
SLP use to sell the "S" pipe, so that you could connect the later model exhausts to earlier model cars.
not sure if they still have it.
but you could buy a piece of 3" tubing, 180* bend, and have a muffler shop cut and weld it into an S shape.
Old Feb 11, 2008 | 01:46 AM
GreasyB's Avatar
I would think that it would fit about the same as on a v8 car. But there will obviously be more modification to do with it then if you were to just buy a cat back specificly for your car/engine.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
drptop70ss
May 4, 2015 08:22 PM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
