Egr
Old Apr 22, 2010 | 12:11 PM
wildracer's Avatar
Question Egr
not to sure if this is where i wanted to post this...
but i had alot of good luck web site good people and very knowlaged about the lt1 motor.... ok i need to replace the egr valve on my 97 z28... how hard is that to do and is there anything i should know before trying this??? thanks guys...
Old Apr 22, 2010 | 03:37 PM
You need a replacement valve, and the gasket, which should be supplied with the valve.
Remove the vacuum hose from the valve. The valve is held on the back of the intake manifold by two studs. Use a 1/2" wrench to loosen the two nuts. You may need a bit of leverage to loosen the valve/gasket from the surface of the manifold.
Clean the gasket surfaces on the manifold. Use a mirror to see the surfaces, and look at the two holes in the manifold to make sure they are not plugged with carbon. Put the new gasket on, put the new valve on, tighten the two nuts firmly on the studs. Reattach the vacuum line. I used a small amount of copper RTV on both sides of the gasket to insure a leak free seal.
Only real difficulty here is you can't really see anything - you have to do it by feel.
Shoebox has a photo that helps:
http://shbox.com/1/egr1.jpg
Old Apr 23, 2010 | 07:04 AM
wildracer's Avatar
thanks my friend
im kinda new to this site but have had alot of help from the guys here ..
this site rocks....
marlar98
Oct 21, 2015 02:02 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
MDZ28
Sep 7, 2015 09:16 PM
Pwilson59
Sep 3, 2015 08:47 PM
Jlo
Jul 29, 2015 03:52 PM
