cutting cat off
Old Jan 13, 2011 | 05:12 PM
hawkins313's Avatar
cutting cat off
just wondering if cutting cat off will hurt my performance wanting to remove it and put on new pipe and muffler just dont want to hurt it.
thanks billy
Old Jan 16, 2011 | 07:42 AM
BMR_M6_Z's Avatar
Re: cutting cat off
I removed my exhaust from the headers back to the cat, busted all of the crap out of the cat and reistalled. Sounds more throaty and haven't had a performance issue. Go for it.
Old Jan 16, 2011 | 09:41 AM
Re: cutting cat off
A hollow cat will probably hurt exhaust flow more than it helps it, unless you installed a pipe between the inlet and the outlet. A "sudden expansion" causes pressure loss, as does the "sudden contraction" that immediately follows it. When the ceramic substrate is still there, it smooths the flow. Any hollow cats I ever heard sounded terrible.
The cat isn't hurting performance. Removing it will not hurt performance. Best thing to do is just leave it alone.
Old Jan 16, 2011 | 10:13 AM
94QuasarZ's Avatar
Re: cutting cat off
I had my cat cut off and just had a straight piece of pipe welded in where it was, sounds a lot better and the car has seemed to perform a bit better with it gone. The only drawback to this really is you will experience a popping noise when coming down from a high rev, but a good tune will clear that right up. Good luck and keep us posted.
Old Jan 16, 2011 | 10:29 AM
bobdec's Avatar
Re: cutting cat off
Had to remove my cat when I installed LT headers, still trying to figure out to put a cat back in the system. It's going to require custom welding that I don't have equipment for. I personally don't like the hollow sound, the exhaust (rich) smell that stinks up my garage after starting it up. And instead of black carbon on my SS tips that used to come off with a wipe of a rag. I now have sticky brown residue that needs polish and elbow grease to remove. If your into racing it may be OK, but if it's a street driver, IMO keep the CAT(s).
Old Jan 16, 2011 | 03:57 PM
hawkins313's Avatar
Re: cutting cat off
ok thanks for the input guys the main reason i am removing is because i believe it is stopped up so just gonna cut it off and install my muffler i bought if to loud i will find a cat to put back on but thanks again for input greatly appreciate it i will let you know how it sounds to me or post a video if i can figure out how
RallyRed701/2
Jul 27, 2015 02:55 PM
BLK1997Z28
May 7, 2015 03:01 PM
Jan 5, 2015 07:14 PM
