Cut Out Location (anyone done this?)
Old May 18, 2008 | 11:31 AM
hey01's Avatar
I want an electric cut out. I already have my cat removed and i want to put the electric cut out right where the Y-pipe joins and aim the cut out to blow exhaust right out behind the front wheel.
anyone ever done this? Is it even possiable with clearance, and if anyone has a route like this do you have any pictures?
Old May 18, 2008 | 12:37 PM
Pontiac_97's Avatar
its going to be stupid loud. there isn't a right and wrong way to mount the cutout. put it wherever it fits or wherever you want it
Old May 18, 2008 | 02:26 PM
hey01's Avatar
im only going to open it under race conditons, that is why im going electric.
Old May 24, 2008 | 02:53 PM
OBE1 95Z28's Avatar
How close will that be to your O2 sensor? Possible to screw up O2 sensor values if outside air can get mixed in with the exhaust flow.
Old May 24, 2008 | 03:35 PM
pcgamer4life's Avatar
As far as I know, you don't have enough clearance anywhere except right under passenger rear seat for the cutout to be mounted (without decreasing ground clearance substantially).
Old May 24, 2008 | 03:42 PM
Moshbmx1's Avatar
I have mine mounted where my cat was...only hangs about an inch below the car if that
Old May 26, 2008 | 10:11 PM
Well you have a DMH cutout, quite a different design than my QTP. I suppose if he goes with DMH (though aren't they more expensive?) then mounting other places would be plausible.
Old May 27, 2008 | 10:06 PM
Moshbmx1's Avatar
I believe that they are more expensive yea...but worth it
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Chet1185
Parts Wanted
Mar 15, 2015 04:29 PM
