Cats?
Old Oct 10, 2008 | 04:01 PM
TBSPW's Avatar
Cats?
I need to replace both of my catalytic converters but i have no clue what i need to buy...i know there is 2 but when i was on summit racing they all look so different...any help would be great.
Old Oct 12, 2008 | 12:40 PM
Are your shorty headers the ones that keep the stock cat converters on the stock locations? If so, you need a drivers side cat made specifically for the dual-cat LT1, with the big triangular flange to match the flange on the headers (which should match the stock dual-car drivers side manifold flange). That is the hardest replacement to find. Random Technology may make one.
If you have stock cats in the stock Y-pipe, they are welded to the Y-pipe. They have to be cut off, and rewelded (one weld on the driver's side, I think two welds on the passenger side. You might want to look for an aftermarket dual-cat Y-pipe, with high flow cats already welded in. Again, Random Tech may make one. Or maybe Borla???
If you do not have the stock dual-cat Y-pipe configuration, you need to match whatever was used in the aftermarket configuration.
Old Oct 13, 2008 | 02:02 AM
ACE1252's Avatar
I think Magnaflow makes a direct factory replacement. I recall them on Jegs.
http://www.jegs.com/p/Magnaflow/759591/10002/-1
I don't know how good they are or how they will fit, but they are cheaper than getting them from GM.
n2oblkz
Oct 12, 2015 01:53 AM
football4life
Oct 4, 2015 07:48 AM
Ks0209
Oct 1, 2015 07:32 AM
Tarizza
3rd Gen / L98 Engine Tech
Sep 20, 2015 03:26 PM
Sep 11, 2015 09:44 AM
