Borla sound without Borla?
Old May 6, 2007 | 11:34 PM
69gto96z's Avatar
I love the sound of a Borla exhaust with an open plate and a cam. Just trying to figure out how I could get the same sound without buying a Borla. Do you think a 3" catback with no muffler y-ing out in the back and exiting through dual tailpipes would give pretty much the same sound?
Old May 6, 2007 | 11:58 PM
turnin20s's Avatar
Should be about the same thing Basically A borola with an open plate nothing goes through the muffler since the exhaust is going to take to easiest passage. Some exhaust might go through the muffler, but not enough to make a difference.
Give it a try. Summit sells the 3" I pipe for like $70 if you wanted to go that route and then just add a y and split it into duals. My car was setup like that when I got it and I hated it personally, but to each his own.
Old May 7, 2007 | 03:50 PM
69gto96z's Avatar
I dont think it sounds good at all unless the car is cammed. I personally think open exhaust sounds like @$$ with the stock cam. I might give it a try, but I will prob go duals instead.
Old May 7, 2007 | 05:24 PM
seawolf06's Avatar
I liked mine with the stock cam and shorties. Now I like it 10x more with the H/C and LT's on it. You can tell when you're driving it when the exhaust starts getting pushed through the muffler. It sounds sweet. At idle is even better as it's pretty much open from the headers back. I did put the largest plate on it to see if it would quiet it down some and it did help when driving around, but there isn't any difference at idle.
I'm going to try to put a video up soon.
I think that the dual pipes with no muffler will sound pretty crappy once you start putting some power through them, but they would sound great at idle. At least put a GMMG or Magnaflow muffler back there after the split off.
Old May 7, 2007 | 09:45 PM
Greed4Speed's Avatar
Borla w/no plates = cutout
Old May 8, 2007 | 04:38 AM
69gto96z's Avatar
I had a cutout on my car, but it didnt have the same pitch as an open Borla.
Old May 8, 2007 | 04:14 PM
seawolf06's Avatar
Not really. It is essentially the same thing, but with the longer pipe and SOME of the exhaust flowing through the muffler it creates a completely different tone.
PopoFormula
Oct 12, 2015 04:19 PM
WobblySausage
Oct 7, 2015 02:44 PM
4586
Sep 27, 2015 01:55 PM
autoxr166
Sep 25, 2015 04:21 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
