Best Long Tube Headers
Old Jan 8, 2007 | 08:54 PM
  #16
Capn Pete's Avatar
I currently have a set of Jet Hots on order with Custom SSI ... hopefully arriving within the next ~week or two ... hoping they work out to be as good as everyone says?? They seem like a good "bang for the buck" next to Pacesetters.
Old Jan 9, 2007 | 08:20 AM
  #17
AL SS590 M6's Avatar
Moderator
The thing that you'll really like about the Jet Hots is the way they fit. The fitment is perfect, there's a half an inch of clearance everywhere around the headers and y-pipe.
One tip. Leave the headers loose until the y-pipe is all slid together, then tighten the headers, then clamp the y-pipe.
Old Jan 9, 2007 | 11:29 AM
  #18
Capn Pete's Avatar
Sweet, thanks Al! Are these Jet Hots likely to bang on the bottom of the car like a lot of people say happens with LTs on 4th-gens?? (curious if I should do the poly motor mounts while I'm at it? ).
Old Jan 9, 2007 | 04:53 PM
  #19
2000GTP's Avatar
Usually clearance problems are a result of worn out motor mounts. To be safe, it wouldn't be a bad idea to replace them. Afterall, a pair of poly mounts runs about fifty bucks and they will be a heck of alot easier to install when the stock manifolds and y-pipe are out of the way.
Old Jan 9, 2007 | 05:10 PM
  #20
Moderator
Nope, there's enough clearance that even with worn mounts they don't hit anything. The set I installed was on a high mileage 98 Camaro.
Although changing them with while doing the headers will be easier.
Old Jan 9, 2007 | 05:38 PM
  #21
Capn Pete's Avatar
Good enough .
Old Jan 9, 2007 | 06:53 PM
  #22
SantaCruz163's Avatar
Kooks FTW
Old Jan 10, 2007 | 03:30 PM
  #23
CamaroRacing12's Avatar
im gonna go with pacesetters
Old Jan 13, 2007 | 07:04 PM
  #24
metallicsniper's Avatar
i hear kooks are one of the best, but if you are on a budget and want a good fitting set of headers at a reasonable price, then go with hooker or pacesetters
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
drptop70ss
May 4, 2015 08:22 PM
4586
Mar 18, 2015 06:31 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
