96-97 y pipe for slp shorties
Old May 27, 2007 | 11:28 AM
1997formula's Avatar
does anyone make a off road y pipe that will bolt up to slp shorties? Its a 97 formula.
Old May 29, 2007 | 08:51 AM
mzgp5x's Avatar
I have a Random_Tech dual cat Y on a lowered 97ss 383 Lt1 and SLP short tubes. Had to cut and re-weld the cross over to fit correctly (slice, bend and weld). It was easy. It made a big difference in exhaust flow with the bullet cats and a D1 ATI blower. I do not like the SLP flange design on the driver side. Adapted a 2 1/2" collector gasket (Summit) to the Y where it bolts to flange. Used 3 rivets to attach it on the crossover pipe flange, and, it is easy to install/ dis-assemble (No loose gm stock expensive junk gasket to hold). Seals good and easy on/ off/ reuseable/ cheep. The only reason to like SLP shorts is ground clearance and Engine access. I also did my own custom cat-back. I guess that's why they call it an... "exhaust system." Hope this helps. B. (97ss - 383 - D1)
Ringmaster72
Dec 12, 2017 10:12 PM
KamikaZ28
May 28, 2015 12:45 AM
slocody
Feb 10, 2003 01:04 PM
97bowtie
Aug 25, 2002 11:00 PM
turbo_Z
Aug 19, 2002 10:50 PM
