93s with Lts need a tune??
Its possible you'll need a follow up tune. As long as you keep the fuse intact for the AIR pump circuit, you shouldn't trip an SES code. However, the EGR is a hit or miss and once you remove it, it is quite possible you'll trip a code.
But there is no other reason as to get a tune other than to delete the codes? I am still running the factory tune on mine.
I didn't remove the EGR with my race headers, I just blocked it all off, but the solenoid is still there along with the piping. All the pipes are just capped.
Aug 24, 2015 06:41 AM
