93 z28 header install
Depends on the specific headers you are trying to install. Procedure will vary. Here's a writeup I did for putting a set of JBA's on my Formula many years ago. Only difference with 93 will be there is only on connection on the passenger side #8 primary for the combined EGR/AIR. All other years have a separate connection for EGR and another for AIR on the passenger side. O2 sensor part # will not be the same. 93 uses single wire, unheated sensors, all other years use 4-wire heated sensors. Watch out for the oil pressure sending unit on the 93.... its right above the oil filter. Other years have it on top of the block, at the back of the intake manifold.
http://www.injuneer.com/JBAHeadr.html
Jul 4, 2005 05:00 PM
CobraEatr
Jul 23, 2002 06:32 PM
CobraEatr
Jul 22, 2002 09:49 AM
