would a 3 series 373 gear work on a 2 series case
Old Aug 11, 2004 | 11:45 PM
zo6vette's Avatar
just wondering if a 3 series gear will work with a 2 series case?
Old Aug 11, 2004 | 11:52 PM
Mindgame's Avatar
Re: would a 3 series 373 gear work on a 2 series case
Drivetrain Tech.
Thanks.
-Mindgame
Old Aug 12, 2004 | 11:18 PM
Jay-Roll's Avatar
Don't think so. Just get a 3 series carrier and be done with it. I don't think their very expensive.
Old Aug 13, 2004 | 01:14 PM
94Zpower's Avatar
by case do you mean the diff casing? if so yes it will fit but for a 2 series gear you need a 2 series carrier and the applies for the 3 but the (diff) casings are the same.
Old Aug 13, 2004 | 01:27 PM
zo6vette's Avatar
yes i mean the case..
Old Aug 13, 2004 | 10:53 PM
a walker's Avatar
Series 3 gears will fit on a series 2 carrier with the use of a ring gear spacer, but 2 series gears will not work on a series 3 carrier.
Old Aug 14, 2004 | 01:00 AM
zo6vette's Avatar
where can i buy a ring gear spacer? how much does it cost?
Old Aug 14, 2004 | 03:00 AM
a walker's Avatar
Check Summit or Jegs. I know Mr Gasket makes some, as does Richmond and a few other people.
They typically cost around $20 or so. If you use the spacer, you will also need longer ring gear bolts. ARP should make some, but make sure they are left hand thread.
Cam's maro
Dec 28, 2014 09:30 AM
Elcojoe
Nov 17, 2014 10:27 PM
naaz90
Jul 27, 2002 08:22 AM
AW/whiteZ-28
Jul 25, 2002 04:09 PM
