Is it worth it to swap from 3.23 to 3.73?
Old Nov 10, 2008 | 09:46 PM
vscott71's Avatar
Its a 1996 Z28 A4. It has 3.23 gears currently. I figure it would probably gain ~.2 in the 1/4 mile by swapping to 3.73. Is it really worth it? I figure I may lose a few MPG also. It will be mostly street driving also.
Old Nov 10, 2008 | 10:37 PM
Depends on your other mods. If it can't make use of the extra RPMs, it's not going to help.
Old Nov 11, 2008 | 09:31 AM
94Z28rag's Avatar
MUCH more fun to drive. I did this back in the day with a basically stock car and it was a blast.
Old Nov 11, 2008 | 09:55 AM
Z-RATED94's Avatar
A good converter would give you better gains, but then again the 3.73s make the converter easier to live with. So get both!!!!!
Old Nov 11, 2008 | 04:02 PM
Airbornec507's Avatar
3k stall, 3.73 gears and some M/T drag radials on a completely stock set up will net you .3 to .5 depending on how bad your traction was to start with. That comparo is given that you are already getting 2.0 to 2.1 60' times. If your getting worse then even better. With the combo I stated on completely stock suspentions and engine/cam I was netting VERY consistent 1.80x 60' times back in the day. So yes 3.73 gears properly set up with stall and DR will help you a LOT. On street tires you'll prolly just roast the tires a lot more. FUN yes. Expensive yes. Does that help your times without the DR? Minimal gains to be had with stock cam.
Devinfoote87
Feb 12, 2016 03:21 PM
realistyc
Jul 28, 2015 07:32 PM
colts0455
Jul 24, 2015 04:51 PM
Boss002
Jul 24, 2015 10:47 AM
