Wiring harness for trans auto trans
Old Feb 21, 2010 | 10:17 AM
jchevy's Avatar
Is the wiring for the auto just a pigtail that plugs into the main harness or is it a whole new harness for the 6 speed. I am looking at swapping to an A4 from my M6 and Im not sure what I need to do about wiring. I have all the computer stuff covered, just dont know about the harness itself.
Old Feb 21, 2010 | 11:40 AM
slowride94z's Avatar
Ill have to look, but I have a 97 auto harness, that can be had
Old Feb 21, 2010 | 11:58 AM
Its one harness
I also have a 97 pcm for and auto
Old Feb 21, 2010 | 12:36 PM
jchevy's Avatar
Check and let me know what you want for the harness. Im covered on the PCM, thanks
Old Feb 21, 2010 | 12:51 PM
jchevy's Avatar
Another quick questions. The engine wiring harness is seperate fromt the harness that runs into the firewall and into the dash? Do I need to tear the dash apart to change to the a4 wiring harness?
Old Feb 21, 2010 | 01:08 PM
The only part of the engine/trans harness that comes into the passenger compartment does so under the PCM.
http://shbox.com/1/harness.htm
Old Feb 21, 2010 | 05:34 PM
95wannabe's Avatar
Go to Shoebox's sight and look at the PCM wiring diagrahms and build yourself a new harness from the exisiting one. Did i say that right so its not confusing???
What i did was keep my existing stock/m6 harness alone, and working from the diagrahms, add a new "leg" or "new harness section" from the PCM to the trans. You can buy the trans connector from GM.
I coiled up all the connectors/harness legs that went to the t56, and ty-rapped them up out of the way...just incase i ever went to m6 again.
Old Feb 22, 2010 | 07:30 AM
Chevyssoccer's Avatar
here is a '99 pin out if it helps.
Old Dec 1, 2010 | 06:29 PM
jchevy's Avatar
Re: Wiring harness for trans auto trans
Its been a while but I am looking into doing this again.
If I am understanding correctly, I dont need to worry about wiring anywhere in the dash, my stock M6 wiring is good there. I just need to get either a new harness for the engine compartment, or build a leg to the trans from the PCM....
Sarahrope64
Nov 27, 2014 11:17 AM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
Rich_z28
Aug 29, 2002 10:44 PM
$hawn
Aug 3, 2002 04:59 AM
