will LSD additive hurt anything if it's not needed??
Old 08-01-2007, 02:14 PM
Z28 Boy's Avatar
sounds like a stupid question - but i have searched and searched with no definitive answer.
if a rear differential does not REQUIRE the GM LSD additive, will it hurt, or otherwise change, the performance of the differantial?
i know there are some gear lubes out there that say it is "already there", so common sense would tell me that it wouldn't matter if you added a bottle of it and you didnt need it.
-brian
Z28 Boy is offline
Old 08-01-2007, 07:25 PM
matLT1's Avatar
You will be fine. The limited slip additive just makes the differential less grabby around turns.
What kind of limited slip do you have that you want to add this to???
matLT1 is offline
Old 08-02-2007, 11:32 AM
Z-RATED94's Avatar
I just changed my rearend fluid last week with some Lucas gearlube. It too said no additive needed. But I threw a bottle of the GM additive in anyways. I figure it can't hurt.
Z-RATED94 is offline
Parts Wanted
03-17-2015 11:24 PM
HectorM52
Parts Wanted
02-11-2015 09:33 AM
BIGCOWL-IMP
11-21-2014 09:40 AM
NED4SPD
09-16-2002 10:45 PM
mjcent922
07-27-2002 12:42 PM
Quick Reply: will LSD additive hurt anything if it's not needed??
