will a 4l60e work on a lt1?
Old Jan 15, 2007 | 09:16 PM
htowncamminz28's Avatar
Thumbs up will a 4l60e work on a lt1?
will a 4l60e work on a lt1?its from a ls1 motor but i have an lt1.
Old Jan 15, 2007 | 09:19 PM
95LT1conv's Avatar
if the input shafts run the same as the t56, then no. input shafts are a little longer on ls1
Old Jan 15, 2007 | 09:21 PM
SCNGENNFTHGEN's Avatar
IIRC they do not match up. I'm pretty sure where they bolt up to the block is different.
Old Jan 16, 2007 | 10:44 AM
MyShibbyZ28's Avatar
The block is different, bolt pattern is different, input shaft length is different, PCM is different. The LS1 is a completely different animal to the LT1.
Old Jan 16, 2007 | 11:58 AM
Performabuilt's Avatar
Supporting Vendor
bell will bolt up , converter will not, Not a good swap idea overall , Though with the right converter and spacers it can be done but probably not worth the extra expense and effort it would involve. better to just get a trans that will fit your car properly
parkers Z28
Mar 11, 2016 08:14 PM
oldschool
Feb 9, 2016 09:21 PM
Jan 5, 2015 07:14 PM
thenewkid
Nov 27, 2014 09:41 AM
Snoman73
Nov 17, 2014 07:22 PM
