Who loves there 12 bolt
Found out i can not get a posi on anything bigger then 31 spline for the 9" so......
I might have to get a 12 bolt. Now the question would be strange or moser, but who loves there 12 bolt and what power are you using it with?
Strange 12-bolt, 33-spline HD posi, ABS for more than 4 years. Absolute plug-and-play.... no noise, no driveshaft issues, no TA issues, no assembly, etc.
Currently running an 800HP 381/nitrous setup, 4.10 Pro Street gears. I picked the Strange because I saw it stand up to close to 1,000HP in George Baxter's 3,900# 30th SS convertible. When I bought it, the only choices were Strange and KTRE.... Moser wasn't making them.
I've got a Moser 12 Bolt with 33 spline axles and richmond 3.55 gears. I love my rear for the street. It has also taken 2 years of 5000 rpm clutch pops on ET streets with a basically stock motor. (thats not to say the rest of the car has lasted as well)
Re: Who loves there 12 bolt
Another car I work on is running 40 Splines with a Spool in his 9".
Infact there are MORE options for the 9" rear end gear and carrier wise than the 12 bolt.
I said i couldn't get a 33 spline with posi. I either have to go to lockers or spool.
I want to stay with posi (for now) my friend has a locker and he said if i had auto i would be alright but since i have t56 i would hate it.
Re: Re: Who loves there 12 bolt
Originally posted by 97FormulaWS-6
Uhm, where the hell are you looking??? I'm currently running 35 Spline's with a Detroil Locker in my Nova, as well as a friend of mine running the same thing... (Both Ford 9" fabbed rears)
Love mine. Moser 12 bolt, 33Spline eaton post, 4.11 motive gears and all the extra goodys. Mostly stock motor right now but I was chewing up diff bearings and said screw it and got a 12 bolt. it will come in handy once I biuld an all forged 355 and force some 10-15 PSI of boost throgh it
Even though I have the Moser, either company is just as good as the other with rear ends. My nova has a strange rear, and so does my dad's 2000hp dragster. So either way its just as good as the other.
Basically what I am saying is, go with whatever is cheaper (best value), part for part.
Aww man, I hate my 12-bolt. It's too reliable, it was too easy to install, I can run a spool in it and of course, the terrible problem of being able to launch off the brake @ 20# of boost w/o having to bring my "recovery shovel" along.
