Whine with a load
Old Jul 29, 2007 | 11:46 PM
eagleknight97's Avatar
Whine with a load
Last week I had a new gear and the install kit put in by a not so great local shop. Driving it the first few days everything seemed ok to me, no noticeable howl that I had previously. However today was the first day I had it on the highway and once I got over 50ish, the rear end started howling a little bit when I would get on the gas even a little bit and then it would go away as soon as I let off of the gas. Improperly set backlash?
Also got a T/A cover put on and its leaking a little bit. Is this because they only used the gasket that came with it and no RTV or is there another probable reason?
With the T/A cover, what should the preload screws be set to?
Old Jul 30, 2007 | 10:44 PM
Anyone got anything?
Old Jul 31, 2007 | 09:02 PM
STAYBG87Z's Avatar
sounds like a pinion bearing.or they set the backlash to tight
Old Aug 3, 2007 | 06:42 AM
so would this situation be detrimental to the rear end or is it more of an annoyance that an actual problem?
Old Aug 5, 2007 | 01:58 AM
Old Aug 5, 2007 | 11:32 AM
If its already started making more noise, its only going to get worse. Could be incorrect pinion depth, poor contact pattern on the gears, etc.
Old Aug 6, 2007 | 01:37 PM
Gun5's Avatar
what gears, my richmonds whine in revesre bad and over 60-70 good thing im getting a 6-speed
Old Aug 6, 2007 | 04:13 PM
The longer you drive it with an improper setup that makes noise, the more permanent it will be.
Old Aug 7, 2007 | 12:02 AM
I went with motive because of all the things I heard about noise from Richmonds
Well, the car needs to get fixed again for reasons other than this so I might as well have them fix another shops mess up.
93 RedBird
Nov 15, 2015 08:24 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
form94
Sep 23, 2015 07:30 AM
cristian1311
Sep 12, 2015 08:16 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
