Where can I order a tranny mount?
Old May 19, 2005 | 09:38 PM
gearslammer's Avatar
I have installed lca's, new stickier tires, stiffer adjustable shocks, and relo brackets. I will be installing trailing arms soon, all to take care of wheel hop that I can't seem to get rid of, so I was told I may also be experiencing some tranny movement. After seeing on a lift I saw the potential and want to get a t mount. A little help guy's?? Thanks
Old May 20, 2005 | 01:07 AM
slomarao's Avatar
Re: Where can I order a tranny mount?
got mine at ls1speed.com
Old May 20, 2005 | 03:32 PM
thanks
Old May 20, 2005 | 08:39 PM
Robert95z's Avatar
Call Dal or Jason Cromer and get stock rubber. Poly will just vibrate the hell out of your car
Old May 21, 2005 | 11:10 AM
89385formula's Avatar
Thats weird, I have poly engine and tranny mounts and my car has no vibration whatsoever, and is 100% smoother than the stockers.
Old May 21, 2005 | 11:29 AM
bunker's Avatar
Same here no problems at all, also added a tubular K-member and still very nice with my setup.
Old May 21, 2005 | 04:39 PM
Robert95z's Avatar
Hm interesting. All i know is that when i added that ES Poly mount i had so many vibrations. I swapped to an LS1 mount and everything was much better
Old May 21, 2005 | 11:31 PM
Are you guy's talking about replacing worn t mounts, or getting one's that take up extra "slack"? What are the Cromers PN's?
mattszm6
Dec 14, 2014 07:09 AM
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
rpm4lalo
Aug 3, 2002 02:35 PM
SavageZ28
17
Jul 14, 2002 11:04 PM
