whats next?
Old Apr 27, 2011 | 06:32 AM
30th_ANNIV_Z28's Avatar
whats next?
recently changed out my rear end from 3.23 to 3.73 and a friend of my told me my next step should be a shift kit then a 2600 stall converter. then he told me i should move on to cam work, heads... does anyone know of anything else i should change out in the transmission (A4 4L60E) on my way to 500 hp?
used as a dd for now but buying a truck so i can use the z for the 1/4 mile.
Old Apr 27, 2011 | 08:04 AM
AL SS590 M6's Avatar
Moderator
Re: whats next?
If you're thinking track then go 3000 on the stall and get it tuned for the stall and gears so that it'll shift right.
Old Apr 27, 2011 | 08:33 AM
JakeRobb's Avatar
Super Moderator
Re: whats next?
I think you'll want to have a performance rebuild done to your trans (or you could just replace it, but that's more expensive). Without that, you're going to be dealing with slipping/burned up clutches and other internal transmission problems.
