What type of fluid in a T56?
Old Aug 8, 2004 | 04:25 PM
Dolby109's Avatar
Well I have the tranny out of my car for (yet another) clutch change, and we drained the fluid, and I wanted to know what type of fluid is the best for it?
I put RedLine MT-90 in my 240SX (which has an SR20DET swap) and it seems great, but will that work just as well for my LT1 T-56, or should I just use regular old gear oil?
I should mention the tranny was rebuilt and it whines a bit, and I think the person who rebuilt it and put it in put heavier weight oil in it.
Also how many quarts of fluid does it take?
Old Aug 8, 2004 | 05:04 PM
unvc92camarors's Avatar
Re: What type of fluid in a T56?
*imo* it doesnt matter what fluid (make sure it's atf fluid though)
just put in something 80w-90 and change it when you're supposed too
also, it takes 4 qts
Old Aug 8, 2004 | 07:29 PM
96Z28TealM6's Avatar
I would use what the manual tells you. I thought Mobil 1 would work for my differential and now my posi-unit is whinning like crazy from 0mph up to how fast I go, so i have to buy a new one now or maybe rebuild it. I think they changed the posi unit late 96 when the SS came out, don't know for sure
Old Aug 8, 2004 | 09:09 PM
the manual just reccommends something equivalent of gm's 80w-90 gear oil
also, you're going to need some limited slip additive
this is a MUST so don't forget it (and also the gasket if you don'thave one yet)
you can get the additive at the dealer, it'll run you about 8$
Old Aug 8, 2004 | 10:13 PM
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
Well, just to clarify, the T56 uses regular dexron ATF (automatic transmission fluid), nothing like 80/90 or gear oil.
Old Aug 8, 2004 | 10:25 PM
Dolby109's Avatar
So I need to use Dextron III ATF fluid, and also add a bottle of limited slip additive (which I can get at Advance Auto where I work)?
Keep in mind I am not talking about the rear end, I am talking about the manual transmission...it just seems since I am getting lots of different answeres that some may be confused.
Old Aug 8, 2004 | 10:44 PM
INTMD8's Avatar
Just use straight regular Dexron 3 ATF. No limited slip additive.
Old Aug 9, 2004 | 04:05 PM
Dolby109's Avatar
4 Quarts of Dextron III?
Thanks...
BTW I am pretty sure that the guy who put the tanny back in last time after it had been rebuilt put gear oil in the tranny, because he said he was going with 90w140 or something really heavy because "the gears had gotten hot" before or something...
Old Aug 9, 2004 | 04:55 PM
hey, i'm sorry man
i've been pointing you in the wrong direction, i was getting my rear end and manual tranny things mixed up
yea, 4 qts of atf, that's it
sorry about that and thanks for correcting me intmd8
Old Aug 11, 2004 | 01:13 AM
Dolby109's Avatar
No prob guys...thanks..
Old Aug 11, 2004 | 10:35 AM
1fastlt1's Avatar
I've heard several times in varriuos places that the Honda ATF is the stuff to use! I haven't tried it yet but I will be when I change it next time!
Richard
Formula Steve
Sep 19, 2023 08:31 AM
2QUIK6
Sep 17, 2016 02:31 PM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
raroz28
Sep 8, 2015 06:10 AM
1slow93z28
Sep 1, 2015 06:22 PM
