WHAT IS THIS????? tranny part **pic**
Old Nov 6, 2005 | 01:30 PM
scottslt1z28's Avatar
ok, this came out of my tranny. what bolt is it???? and where does it go??
http://tinypic.com/fdesrq.jpg
http://tinypic.com/fdestw.jpg
thanks guys
Scott
Old Nov 6, 2005 | 02:10 PM
MachinistOne's Avatar
Re: WHAT IS THIS????? tranny part **pic**
Where did you find it? In the pan? Look at the heat(blue) that was generated at the head when it got wacked...ouch!
Old Nov 6, 2005 | 02:18 PM
i found it in the pan that shields the torque converter and the flywheel (NOT the transmission pan)............WTF IS IT???? i can see it backed itself out and then was sitting against the pan and rubbing on the torque converter as it spun.
yes it disturbed me as well, thus the reason i am asking WTF it is.........LOL
thanks guys, Scott
Old Nov 6, 2005 | 02:59 PM
FastZinTennessee's Avatar
It's a bolt that holds the rear main seal housing on. I know because I had the exact same thing happen to me. I was at the end of making an 1/8 mile run and all of a sudden heard this horrible clanging and clattering sound. I thought I had blown the motor up. Upon removing the torque converter shield I found a smaller sized black bolt was loose in there. I wouldn't worry about it, there are three other fasteners that hold the rear main housing on and it shouldn't start leaking.
Old Nov 6, 2005 | 07:06 PM
shouldnt leak??? i think i might need to replace it. i wonder how the hell it back out.....WTF, anyways. Thanks man i really appreciate it. Now i know what im dealing with. HRmmmmmm.
Old Nov 8, 2005 | 11:14 AM
ttt
Old Nov 9, 2005 | 03:02 AM
smoknta's Avatar
Thats a quarter........
Old Nov 9, 2005 | 03:31 AM
OMG, thankyou. The bolt was strickly in there for a reference to size. I knew it looked somewhat familiar, but i just couldnt put my finger on it.
you SIR are my hero
Old Nov 9, 2005 | 05:27 AM
smoknta's Avatar
you SIR are my hero
LOL....
Old Nov 9, 2005 | 02:48 PM
Fast Caddie's Avatar
thanks guys, Scott
Going from this description, it has to be a flywheel-to-TC bolt or crank-to-flywheel bolt. It's been a while since i've had the tranny out, but i think those bolts look like that (only the outer part of the body is threaded, the part towards the head is smooth to clear the bolt hole surfaces).
There are only three bolts holding the TC and flywheel (flexplate) together, and either 5 or 6 bolts holding the flexplate to the crank, so you might want to get under there and put it back in ASAP.
The RMS housing bolt could be a possibility, but i figured the flexplate would block it from getting in the inspection cover area.
Old Nov 9, 2005 | 03:04 PM
well i havnt been driving becaue of this......LOL i know i need to get it fixed, haha. i know its not the flywheel to TC bolt cause those are huge. I dont know, im just gonna drop the tranny and figure it out, then replace it.
that might be the best thing to do
Old Nov 11, 2005 | 04:12 AM
Loony's Avatar
Possibly too late but that looks EXACTLY like a flywheel bolt. I could go take a picture of my stock ones if you want me to.
Old Nov 11, 2005 | 07:51 AM
that would be cool........actually NO u arent too late
i havnt pulled the tranny yet, sooooo YOU WOULD BE GREATLY APPRECIATED if you would do that (take a pic that is)
also, what do you recommend replacing it/them with
i am planning on taking my tranny out this weekend (i.e.- tomorrow)
thanks man
Scott
Old Nov 11, 2005 | 11:02 AM
multicar's Avatar
Dude, it looks like the rear main seal plate bolt. Flywheel bolts are way fatter then that....about 1/2" shank. Convertor bolts are about 3/8". That bolt looks about 1/4". Use the blue lock-tite on all of them.
Doug
novaiiman
May 15, 2016 11:36 AM
importkiller94
Jan 17, 2015 09:03 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
siguy
Nov 27, 2014 10:07 AM
