what should i shift at?
Old Aug 7, 2005 | 05:54 PM
NEOS97SS's Avatar
right now i have a stock tuned tranny with a 2800 stall and i have swapped my 3.23's for 3.42's. im running a lt4 hotcam and a set of stage 2 P&P heads with a thermal coated P&P LT1 intake and a 58mm TB with underdrive pullies CAI, basically every bolt on available. i run 275/40/17s on the street and 275/50/15s at the track. what are some good shift points to start with? and whats everyone else shifting at. I also have pcm4less's OBDI conv.
Old Aug 7, 2005 | 11:44 PM
Lower's Avatar
Re: what should i shift at?
Most A4 guys DON'T shift.
Old Aug 7, 2005 | 11:47 PM
NEOS97SS's Avatar
thanks a lot a$$...now unless you have something useful or constructive to say, SHUT IT
and this may be a stretch for some to grasp but A4's have shift points too, we just dont have to do the shifting. so incase you are still clueless i was referring to where should i program it to shift at.
Old Aug 8, 2005 | 12:16 AM
Scream And Fly's Avatar
I don't think Lower was being a sarcastic. It's actually best to keep the shifter in 3rd (D) when racing from a light.
I'm not sure about the shift points part - a lot of that depends on mods, etc.
Old Aug 8, 2005 | 01:09 AM
Lower's Avatar
Then why isn't this in the Computer Diagnostics/Programming forum?
I seriously considered that you had meant shift point, but gave you the benefit of the doubt at being smart enough to find which forum to post your thread.
I was wrong in overestimating your intelligence. My mistake.
But thanks for being a complete jerk about it.
And good luck getting help, what with your attitude and all.
Old Aug 8, 2005 | 01:38 AM
ChicagoTransAm's Avatar
Only true way to dial in your shift points would be a dyno. See where your power band is and keep the engine there
n2oblkz
Oct 22, 2015 02:31 PM
WobblySausage
Oct 7, 2015 10:09 AM
Bxlt1
Sep 29, 2015 03:18 PM
marlar98
Sep 19, 2015 07:53 AM
