What part is this??
Old Oct 9, 2007 | 08:24 PM
marshall93z's Avatar
What part is this??
And how important is it?
Transmission(700R4) worked when it was taken out. I am planning on putting it in my M6 car and was gonna clean it up/change filter and stuff like that, then I saw this crack in that part!
Old Oct 9, 2007 | 08:37 PM
thesource2004's Avatar
Oh crap thats your flux capacitor .......
Old Oct 9, 2007 | 08:38 PM
I've already came back to the future, so I guess I'm good.
Old Oct 9, 2007 | 08:42 PM
Then fawk it .......
Old Oct 9, 2007 | 09:10 PM
Performabuilt's Avatar
Supporting Vendor
Thats the forward clutch accumulator housing cover, eventual failure will result in suddent loss of all forward gears. You need to go to a trans shop and ask if they have and aux valve body for a 700r4.
Old Oct 9, 2007 | 11:54 PM
MIKZ86TA's Avatar
X2. Superior also sells a HD cover thats steel and thicker. Corrects another Aux VB issue of the piston pin coming out. After you remove that cover you need to check the pin to see if its coming out. Here is some good info on that. Also list the Superior part #. The part is about $10 nowadays http://www.specialtytrans.com/specia...0R4-Aux-VB.htm Hope this helps
Old Oct 10, 2007 | 02:54 PM
I wonder what caused it to break?
Old Oct 10, 2007 | 10:30 PM
And why can I not just put another cover on it?
Old Oct 11, 2007 | 12:10 AM
MIKZ86TA's Avatar
You can put another cover on it. Ive seen broken ones B4. Cheap thin aluminum, its like an accumilator, so its got a piston and thick spring in there. Pressure, maybe some douch overtightened it B4 causing a stress fracture. The spring is directly against it and the piston pushes on the spring. The HD part cures a 'walking out' probelm with the piston center pin and is thicker to cure the cracking issue. Just an option. Unless you find a used one off a junk tranny the GM part from the dealer is going to cost more than the HD part. Part # is on the end of it. Options yours. Hope this helps
Old Oct 11, 2007 | 02:37 PM
If it's the cover, why do I need the aux valve body? Or do I just need the cover?
Thanks for the link!
Old Oct 11, 2007 | 04:29 PM
MIKZ86TA's Avatar
It would be more likely a tranny shop will get you a used AuxVB in its entirity from a donor trans. I would inspect the one you have inside and out gro any more stress fractures, etc. If youre uncomfortable with re-using that one, try to locate an entire assembly. Like PerfBuilt said, just try a local tranny shop. Dealer is probably high enough on the cover alone, Im guessing the entire unit will be outrageous. If you think your assembly is OK and it was just the cover, then replace the cover by itself. Just throwing out some options for ya. Hope ya find it and get it back on the road =)
Old Oct 11, 2007 | 11:33 PM
I'll inspect it first, then try the HD cover and see what happens!
Old Oct 12, 2007 | 12:09 AM
MIKZ86TA's Avatar
Be sure the spring isnt broken (tho Ive never seen an AuxVB spring breal just a 1-2 Accumilator spring) and the piston isnt cracked either. The piston seal needs to be good and snug, Meaning it will be tight in the bore. Also follow the pin-length checks on the link I posted B4. Hope this helps and Good Luck Bud!
Old Oct 12, 2007 | 05:29 AM
Sure thing!
Old Oct 12, 2007 | 02:46 PM
One more question.
I know the 700R4s aren't electronic, so what all do those wires control inside of it?
