What is "normal" aftermarket gear noise?
Old Apr 23, 2006 | 06:58 AM
sikz28's Avatar
I just installed my 4.10's and they only make a little whining noise at 45mph and above. The faster I go the louder the noise gets. Is this the normal aftermarket gear noise that I've read about or do all the aftermarket gears make different noises for different people?
Old Apr 23, 2006 | 07:17 AM
87DJP2001's Avatar
Re: What is "normal" aftermarket gear noise?
Nothing is normal when you replace the stock gears. you get noise for some of these reasons:
Gears are cut for a racing application.
Ratio not suited for a daily driver
poor installalation & gear set up
etc etc
Old Apr 23, 2006 | 08:33 AM
BitterOldMan's Avatar
Ditto, silence is normal unless there is an install problem or the gears are more straight cut for strength. Who made your gears?
Old Apr 23, 2006 | 08:38 AM
sikz28's Avatar
[QUOTE=. Who made your gears?[/QUOTE]
I am not really sure. I bought them from nationaldrivetrain.com. They are supposed to be their platinum torque gearset, but they came in a motive box.
I am sure they are set up correctly I did it myself.
Old Apr 23, 2006 | 06:23 PM
84firebird's Avatar
well my buddy put ratech's in and they're quieter than stock gears, but they should be silent unless they are race gears or something
Old Apr 23, 2006 | 07:48 PM
onebadponcho's Avatar
Let's see.....
I believe I bought my gears from national drivetrain also; it's been awhile. My gears are Motive, and the person I talked to on the phone said they would be pretty noisy, but I bought them anyway like a dumbass.
Yeah, they are noisy. I even had them rechecked and reinstalled by Randy's Ring and Pinion (very reputable), they said my gears are fine, wearing fine, everything was good.....but they're still noisy. I just think a straighter cut gear built for strength rather than silence is going to make some noise.
Old Apr 24, 2006 | 07:30 AM
Javier97Z28's Avatar
Moderator
My Strange gears are straighter cut, have been holding up great, are a bit noisy on decel and at certain MPH you can hear them more than others, but I don't care as long as they last, which they have.. held up to over 100 track passes, and quite a few miles.
Old Apr 24, 2006 | 08:03 AM
wrd1972's Avatar
From what I have read most 4.10's whine just a bit.
I dont consider myself an R&P pro but I feel very confident in my work, I have done several Jeep install and came out perect dead silent every time. Although the Dana gears are easier to do.
Anything more than a bit of whine is usually a bad install. I had motives orange box and they screamed, I got the Randys Yukons and they are much better, they are actually a 2 cut gear very similar to OEM GM spec plus they have a lifetime warranty so if I rip the teeth I can just put a new set in for free.
Mine have actually gotten a bit quieter as time has gone by. I also got a stud girdle which allows more fluid to be used to reduce the temp, that has helped some not to mention the loud Borla and no cat.
Old Apr 24, 2006 | 12:49 PM
sikz28's Avatar
Thanks for all the replies, after a couple of days and about 40 miles of EASY driving the noise is almost gone. For $135 shipped including the install kit I have nothing but a for nationaldrivetrain.com
warmeck
Mar 22, 2015 10:28 AM
Fatdog2
Feb 12, 2015 12:24 PM
Collector Car
Jan 5, 2015 10:58 AM
Noenav
Dec 6, 2014 07:35 PM
