What kind of T-56
What kind of T-56
I am currently converting a 3rd gen 5 speed to a T-56, but first i need to get one. Do i need to get one from a chevy or are they the same for other makes? Probably not, but i had to ask..
M29 was only offered in 93 and has deeper gear ratios than the M28. Stock T56's from a F-body can handle a lot of power before they break. Even then you can get it upgraded with cryo/micronite parts or "Viperize" it iwth larger input/output shafts and what not. If you search you can find some good info, also there are T56's for sale all the time so finding one won't be hard.
The easiest swap for the 3rd gen is what's called an aftermarket T56. With an adapter it will bolt on to a blowproof bellhousing and put your shifter in the correct location. Call D&D for help.
Steve
Steve
Formula Steve
Sep 19, 2023 08:31 AM
karpetcm
Sep 29, 2015 10:08 AM
