What kind of gears?
What kind of gears?
Ok, im putting in a 383 with LE2 or LE3 heads with custom cam. Changing the tranny and getting a 12bolt rearend. What gears should I get with this. 3.73s seem to be popular but Im getting alot of people saying it doesnt do much. That maybe I should go with a 3.90. I wanna know yalls opinion on this..
Jack
Jack
Might want to mention whether you are installing a 4L60E, a T56 or some other tranny. That will affect gear selection. Also need to know the estimated flywheel HP, engine redline or anticipated shift points, tire diameter and 1/4-mile MPH if that is what you are using the car for. You want to pick a set of gears that lets you run through the traps at the cars maximum MPH, while not shifting out of the 1:1 gear (3rd in an A4, 4th with an M6).
is this a Daily driver or trailor queen?
DD = 3.73s usually
Trailor queen usually has some taller tires and go with 4.10s or higher.
If you are in the middle I'd go 3.90s and run the 1/4 and watch where you shift and adjust tire height accordingly, like injuneer said.
DD = 3.73s usually
You might want to investigate the information I requested, so that you don't end up spending a lot of money for a 12-bolt rear with the "wrong" rear axle ratio.
This is a good question because i've been thinking about changing the gear in mine, so I'll see what you think and give you as much info as possible, My car is a daily driver and i more then occasionally get on the highway and run it up over 130 but i was thinking since most of the time it seems to be just a red light racer that a little more low end might be nice without dropping a lot of money in the engine, I have a lt1 its a jasper crate but its built to stock spec, 100 shot n20, cold air intake and that's about it, I just had my trans rebuilt (4l60E) with a trans-go kit, corvette servo, upgraded converter etc, I don't plan on doing much to the engine but i do plan on in the near future to upgrade the map (granatelli for cold air) digital 6 so i can can a perf tune and ret for the n20. Im running 18" rims all the way around but i used a tire calc and got the tires sizes so the overall tire dia is very very close to stock. I plan on upping the shot to 125 also. I guess thats all I can think of.
Thanks.
Thanks.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
