We really need an LT1 sticky on clutch/flywheel options
Yes it is, here's the link for it to make it easier to get to and order.
http://www.jegs.com/i/Ram%20Clutches/798/910/10002/-1
Edit
They had this part listed as a 11 x 1 1/8 - 26 disc for an LT1 a month or so ago. Not the first time they posted something wrong. So now it looks like before and the 300/900 and the 900 PowerGrip disc can not be ordered seperately for an LT1.
Thanks for the updated. First port edited.
JD
JD
Well, I went to Autozone and picked up their LT1 clutch kit. $204 out the door including tax. For some reason they gave me 10% off for picking it up, which is reflected in the price.
Here is what I found: Part Number NU31265. Two things I noticed.
1) There is no Valeo stamped in the pressure plate, but it looks identical from the pictures of the Valeo model.
2) The Clutch disk only has four springs, versus the stock five. Is this an issue? What is the purpose of these springs, to take the initial shock of a hard engagement of the clutch, or intermittant spikes in torque? This is the only part that has me a little nervous.
Hope this is helpful for others.
Box:
Clutch Disk:
Pressure Plate and Bearing:
Dan
Box:
Clutch Disk:
Dan
I borrowed one from a parts house and had it pressure tested and it was stronger than the stamped Valeo PP. Also notice the aluminum case is much better looking than the Valeo cases which all look like they have cracks and flash.
The purpose of the springs is to reduce the impact on the drivetrain when the clutch is dumped. I am sure this clutch is fine for stock or lightly increased power levels.
I personally dont think the 1/32 would make a difference. The clutch hydraulics will self adjust to a thin worn disk, a OEM spec thickness disk or even a slightly larger than OEM spec disk. My spec 3+ is .238" thick were my stock disk was .218" thick.
I have seen this PP once before, up to a few years ago they were rather rare since the Valeos were still around. It is a chinese knock-off from what I was told by my clutch guy.
I plan to install this in three days so I'll report back with my findings.
Dan
Well, I got it all buttoned back up. Holy Crap! It's like driving someone else's car!
The clutch grabs pretty much immediately off the floor. I stalled it twice getting used to it in the first couple of minutes, which is weird since I've had the car since new with 91k on the old clutch. I was very used to how it drove. I guess the wear was so gradual over 91k miles that I got used to having the engagement point get further and further up the pedal travel.
I was worried that resurfacing the flywheel would make the engagement point higher than it should be, but no worries there!
The clutch seems to be holding well, even with my 325-330 rwtq. No chatter or weird pedal feel. Very smooth.
Dan
Dan
Dan
Dan
